two speed fan setup. best choice?
Old Aug 4, 2003 | 10:52 PM
GendoIkari69's Avatar
GendoIkari69
Question two speed fan setup. best choice?
I have a dual fan from a Ford car. It's got three wires, ground, hot for low speed, and hot for high speed. I've seen thermostats that turn power on and off and those that variably control the speed of the fan. What's the easiest way to create a setup where the fan is always on low and then kicks to high at a certain temp. Stuff like, running for 30 sec after the truck is off and coming on when the A/C is turned on would be a plus.
Old Aug 8, 2003 | 04:53 PM
javi2001's Avatar
javi2001
Usually low speed is connected to AC clutch same wire, so as sonn as AC is working, fan will work also, it's improve AC performance at iddle.
Hi speed wire usually is connected to an electrical switch which in case engine temp is going high then fan will get hi speed for maximun cooling.
You should verify before do anything if yor fan can work with both wires energized, if not you'll need an additional relay to avoid problems.
Regards;
Old Aug 9, 2003 | 03:45 PM
UglyBeast's Avatar
UglyBeast
What car did you get the fans from? Im thinking of doing the same thing, I'm just worried that it won't be enough to cool my 351W
Old Aug 24, 2003 | 01:02 PM
GendoIkari69
It came out of a Ford Contour. Don't know the year. It fits nicely along the top, driver's side, and bottom. The passenger side has a 2-3 inch gap off the radiator and extends about 3 inches past it. I'm going to try and fabricate a side piece. I found a website with info on setting up a two speed fan with a thermostat. Once it is all in it should switch to high via switch, temp, or the A/C compressor coming on. The only thing missing will be a delay after start up and it running 30 sec or so after stopping.
Old Sep 29, 2003 | 01:34 PM
GendoIkari69
I was talking to the guy who gave me the fan the other day and he said he was mistaken about which vehicle it came out of. The fan was out of a Lincoln Continental. He was unsure of the vehicle's year though.
