Aerostar Ford Aerostar
Starting problems
Old Aug 4, 2003 | 09:46 PM
shaun327's Avatar
shaun327
Starting problems
ok, I have an 89 aerostar, 3.0, automatic (A4LD). The troubles began with it not wanting to start after it had warmed up to operating temp. After cooling down, it would start. It progressively got worse, to the point that it will not start at all now. I can jump across the start relay (on the firewall) and it will always start. I have replaced the start relay (on the firewall), the ignition switch, the key cylinder, and the the neutral safety switch.
I am at a loss!!!!! HELP!!!!!
Old Aug 4, 2003 | 09:48 PM
shaun327's Avatar
shaun327
Starting problems
oh by the way, the overdrive would slip in and out until it disappeared during the same time frame. I don't know if this is related or not.
Old Aug 5, 2003 | 12:27 AM
afcro's Avatar
afcro
Starting problems
Shaun, It sounds like the starter itself. When you leave it off for a while, your battery comes up full again. Check your connections on the starter, they have to be tight, then failing that try this, the next time it doesnt start, crawl underneath and give your starter a good whak with a hammer. If it starts then you know the starter has a dead spot. If you need to replace it, Its a very simple job. Good luck - afcro
Old Aug 5, 2003 | 11:52 AM
shaun327's Avatar
shaun327
Starting problems
well...I don't know, it will not crank over with the key, but I can bypass the start relay and the starter will engage right away. so the starter is working properly. But not with the key switch.
This is the case, even first thing in the morning. the key switch will not crank the engine, but if I jump across the relay it will crank, which seems to me, that all the connections to the starter are good. There seems to be a missing link in the wiring for the starting circut.
Old Aug 5, 2003 | 12:42 PM
aerocolorado's Avatar
aerocolorado
Starting problems
Get out the owner's manual and locate the fuse for the 'Starter Relay' . Check it to see if the fuse has blown or is partially dislodged.
Old Aug 5, 2003 | 02:31 PM
shaun327's Avatar
shaun327
Starting problems
I checked that....it is good
Old Aug 6, 2003 | 02:10 PM
Mikeman's Avatar
Mikeman
Starting problems
Did you check for voltage at the relay terminals which close the relay (not the terminals that provide power to the starter)? Make sure the ground for the relay is good as well. If you're not getting power to close the relay, then look upstream, including the ignition switch.
nomad27
Modular V10 (6.8l)
23
Mar 3, 2019 02:55 AM
rc31080
Jul 21, 2014 01:05 PM
vfrf2
Apr 25, 2014 12:48 PM
chappys4life
Jun 29, 2012 12:05 AM
GMCfourX4
1997 - 2003 F150
Apr 9, 2007 10:06 PM
