1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Do all our aftermarket swaybars clamp to the differential?
Old 10-18-2015, 08:47 PM
Brute440's Avatar
Brute440
Brute440 is offline
I grew up with the older Dodge trucks and fell in love with the Superduty. I have a 2015 F250 4x4 and was looking in to adding a rear swaybar. Our older Dodge trucks use sway bars that mount to the spring perches on the axles. The HelWig kits that I see for the new F250 looks like they clamp to the axle near the differential. Does anyone know if that is the only type of sway bar available for our f250?
Old 10-19-2015, 07:44 AM
Tom's Avatar
Tom
Tom is offline
Hellwig is the only one I've heard of in the aftermarket. Looks like the OEM unit uses brackets that attach to the shock mount. Check out this thread:
https://www.ford-trucks.com/forums/1...-pictures.html
Old 10-19-2015, 07:50 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
the Ford rear anti-sway bar...
is/was an option from the factory... my 2012 has this option..
if you had ordered the Camper kit .. it is part of the slide in Camper kit option.
my truck has trailer and camper options... so you can have both at the same time.
order the parts from Ford... and bolt them on.
Old 10-19-2015, 07:08 PM
Optimistic Paranoid's Avatar
Optimistic Paranoid
Optimistic Paranoid is offline
I believe Roadmaster also makes rear anti-sway bars.
Regards
John
Old 10-19-2015, 07:43 PM
Omega Man's Avatar
Omega Man
Omega Man is offline
I just removed my swaybars, would a 99 F350 factory swaybar fit the newer model?
Mack3006
2017+ Super Duty
26
03-25-2020 12:38 PM
Dunderberg
12-14-2018 04:56 PM
Mulepick
03-26-2008 07:55 PM
mjlevi
09-03-2006 02:55 PM
narcicus
07-18-2003 02:50 PM
Quick Reply: Do all our aftermarket swaybars clamp to the differential?
