newbie needs help!!!
Old Aug 4, 2003 | 08:49 PM
jollygiant_57's Avatar
jollygiant_57
Unhappy newbie needs help!!!
the 94 f350 p stroke 4x4 5sp
that im trying to buy has a broken speedo, i guess it recently just quit working? what do you guys think it could be?
ohh yeah the stupid abs light keeps flickering and there is plenty of brake fluid in the master cylinder, any ideas??
sorry im new to the allmighty diesel world, i was wondering what should i do when i first get this truck? i planned on changing all fluids (diifs, tranny,tcase,coolant,oil) but what else is there to do besides airfilter, and fuel filter???
thanks for all the help!
Old Aug 4, 2003 | 09:01 PM
lipton's Avatar
lipton
check the abs sensor in your rear differential. the servo may have gone bad. I would assume your cruise control (if you have it) isn't working as well.
Old Aug 4, 2003 | 09:51 PM
RRMike's Avatar
RRMike
Yeah if you had the e4od it would probably be blinking the od off light at you as well. The tone ring is either unplugged or gone bad or the wiring has gone bad or broken somewhere.
Old Aug 5, 2003 | 03:33 AM
mike the mechanic's Avatar
mike the mechanic
Just a hint: On a diesel check the coolant "DCA" level. DCA is a chemical you add to the coolant. It's purpose is to counteract the acidic levels in the coolant that a diesel engine creates. If the DCA levels fall too low "electralisis" takes place on the water side of the cylinders and "rots" it away. I believe you can get the test stips an additive at any NAPA store or if all else fails any International truck dealership will have it.
Old Aug 5, 2003 | 06:48 PM
f350xlt460's Avatar
f350xlt460
speedo broke? just get a GPS, it tells your speed and can give you nearly anything you want while driving.
I have the Garmin Street Pilot 3 GPS, it was worth the investment.
Old Aug 6, 2003 | 01:38 AM
jollygiant_57
i will be sure to test the coolant, whats the deal with this EVANS stuff? they say you hardly have to change it? whats up with that and does it work?
Old Aug 6, 2003 | 01:17 PM
RedTaurus94's Avatar
RedTaurus94
I'm not running the Evans coolant, but I have read on here that coolant additive is not required with it, and that it doesn't ever need changing.
Read some of these threads to learn more about it: CLICK HERE
