8BA Pan and Pick up
#31
Larry I consider myself to be very fortunate with shops like Dennis Carpenter, Fatman and numerous others within a short drive. I got side tracked with Xmas stuff at the weekend but with a week off between Xmas and New Year the truck should be back together and driving. Can't ask for a better Xmas gift.
#32
#33
Interesting numbering scheme on the cylinders "before".
It would really finish off the engine if you got the spark plug wire looms. The wires should go behind the thermostat housing, across the manifold in front of the carb.
Do your self a big favor and put on the generator and the belts before installing, if your stand will take the added weight. How are you going to lift it?
#34
Ross, I have those loom brackets in one of the boxes that came with the truck. Couldn't figure out what they were, now I know. Tnx.
As for the cylinder labeling, well I wasn't familiar with the flat head. It soon became obvious when I removed the heads and found TDC on the #1 compression stroke wasn't what I thought it was. All good now.
I used this rig to get the engine and trans out, and will reverse the procedure. The beam is 2 x 4 x .25 wall aluminum and works like a dream.
#35
#36
#38
#39
#41
#42
After a great Xmas got back in the garage this morning. Had the battery on charge for a day or two. Hooked it up and the engine would barely crank. Looked at the wires and the positive lead had a cracked battery end. Off to the auto store for a replacement. Hooked that up and still barely turns over. Noticed that the cable at the solenoid was very hot. Too hot to touch. New solenoid on order. The engine will turn over with a ratchet wrench on the crank bolt so there's no problem there. This truck simply does not to want to be rushed.
#43
#44
#45
