Error code P0475
Old Oct 16, 2015 | 03:23 PM
hondamxr's Avatar
hondamxr
Error code P0475
I have read a lot of the post in this forum about the same issue but I can't figure out how to fix mine. I went and got my truck smog and it failed because of this code. I then changed the sensor cleaned out the tube and I still can't figure out how to get rid of the error code? any advice
Old Oct 16, 2015 | 03:46 PM
Thomas White's Avatar
Thomas White
P0475: Exhaust pressure control valve malfunction / Open/grounded ckt., solenoid /open/shorted, failed PCM.
DIAGNOSTICS
1. possible causes:
a. shorted to power
b. open/grounded circuit
c. damaged solenoid
d. damaged PCM
e. Disconnect EPR harness connector.
f. Measure resistance between Pin A and ground.
g. Deleted EBPV
2. Do you have Power to the GY/R wire/pin?
3. Measure resistance across EPR coil contacts A and B. Spec: 2.5 - 12 ohms? If not, replace regulator.
Old Oct 16, 2015 | 03:48 PM
jhl3's Avatar
jhl3
Is your EPCV unplugged or deleted?
Old Oct 16, 2015 | 04:24 PM
jhl3's Avatar
jhl3
Attached is a link to a post about adding a resistor in-line in the plug if it is unplugged intentionally or if it has been deleted. You will be fooling the PCM.
https://www.ford-trucks.com/forums/1...pv-sensor.html
Drew93OBS
29
Jun 6, 2022 08:49 PM
NotEnoughTrucks2014
1997 - 2003 F150
15
Sep 7, 2021 10:49 AM
Iceman5192
1997 - 2003 F150
Aug 15, 2013 09:54 PM
86capriASC
1997 - 2003 F150
13
Aug 7, 2010 10:48 PM
Tomget
1983 - 2012 Ranger & B-Series
Sep 18, 2008 11:26 AM
