Cracked Dash? No problem! Cheap, easy fix.
Old Oct 14, 2015 | 01:40 AM
75Three90's Avatar
75Three90
Originally Posted by WhatsAChevy?
Quite a few years back, I did this to a '78 LTD. I started by trimming out the curled edges of the cracks further out with a razor blade, then rough sanded the entire pad. I then filled the cracks with silicone and allowed it to set up completely. I went back with the razor blade and icarefully trimmed the excess silicone flush with the original vinyl. I found a thin vinyl at the local fabric store (JoAnn Fabrics, i think) that closely matched the original and layed it on the pad in the sun for a couple of hours. I used my heat gun to form the vinyl to the pad and let it cool. Using 3M Spray Trim Adhesive, i sprayed both the liner side of the vinyl and the dash pad, allowed it to set for a couple of minutes, then carefully layed it on.
I used a wallpaper roller to gently adhere it while working out any bubbles starting from the center and working outwards. For the defroster outlets i cut a small + slit and wrapped the vinyl in.
the way i did my defrost vents i covered the dash completely (even the vents) flipped the dashpad over and sprayed the carpet then made a straight cut with a razor blade and folded the carpet in. So far so good, as far as the screw hole near the windshield i cut carpet away from them then lightly painted the vinyel that was showing black. Cant even notice it
Go-on3
2015 - 2020 F150
May 14, 2018 07:13 PM
reamer
46
Feb 23, 2015 08:12 PM
53pickemuptruck
Jul 23, 2014 07:55 PM
Cods81bronco
Jun 10, 2012 12:14 PM
SCRWDRVR
Delaware Chapter
20
May 8, 2008 06:15 PM
