Sponsored by: Real Truck
Front caliper recommendations
Old Oct 11, 2015 | 01:55 PM
artieb's Avatar
artieb
Hi, 01 F350 4X4 Superduty. I've been in a losing battle with the front caliper's sticking. Any brand that usually works better than others? Which ones to stay away from? I did a search which got to involved with other issues.
Thanks ,Artie
Old Oct 11, 2015 | 03:44 PM
davester250's Avatar
davester250
you've gone through multiple calipers which were sticking?
Really points to something else, like maybe the rubber line to the caliper, or maybe the master cylinder or ABS system.
Old Oct 11, 2015 | 03:48 PM
artieb's Avatar
artieb
Nope, I just banged the caliper's back and forth, until they released, while opening the bleeder, when compressing. Then bled as normal. Been on the truck 4 or 5 years.
Old Oct 11, 2015 | 05:14 PM
nojoke327's Avatar
nojoke327
So what exactly is the issue. They bled fine and released fine? Am I understanding that correctly? Unfortunately changing superduty calipers every 5 years isn't terribly rare. I don't use anything but Ford products for brakes.
Old Oct 11, 2015 | 05:29 PM
Chuck's First Ford's Avatar
Chuck's First Ford
could be a collapsed line.. the lines have an inner and outer.. you can not see the collapse ...
forcing the piston back in will expand the inner hose .. so it works again...
temporary .
Old Oct 11, 2015 | 06:15 PM
artieb's Avatar
artieb
I understand how a hose can do the one way valve thing. I have all 5 new hoses i will install. I'll get it jacked up and confirm either hose and or caliper. I'll see what a OEM caliper goes for, also.
Old Oct 11, 2015 | 11:24 PM
Bently_Coop's Avatar
Bently_Coop
Are your slide pins freezing? Do you have the newer slide pin kit? What kind of grease is being used on the pins?
Take a look at the link below for slide pin lubrication and updated pins.
2004 F250 Brake Caliper Slide Pin Upgrade
mikeinri
Jul 2, 2015 10:45 PM
RJB71
Oct 9, 2014 12:29 PM
hownottodrive
1997 - 2003 F150
Jun 10, 2013 11:23 AM
JoSHN
2004 - 2008 F150
Oct 1, 2011 07:29 PM
boaterdude83
Sep 16, 2008 12:21 PM
