New to the Forum, and Diesels
  #46
Old 10-30-2015, 07:20 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
Originally Posted by cowmilker08
Nick, tried to rep you, but got denied.
I run Howe's in the winter and occasionally add some bio-clean to prevent algae from growing in the system.
I also use rotella oil, but I only change it every 5000 miles. Fuel filters are changed every 15000 miles in my trucks.
As far as mods go. First you need to figure out why you have to hold the throttle when the truck first starts. The problem could be the injectors, but there are several other possibilities too. Does it smoke when it starts? The chip should not be run w/o an EGT gauge. Most guys will install an EGT gauge, TFT gauge, and a boost gauge. I would also recommend the 6637 air filter mod (or other non-K&N filter mod) and upgrade the down pipe. The downpipe and air filter are cheap mods and will really help the engine.
First thing is to figure out why it starts hard though.
Got him Phil!
  #47
Old 10-30-2015, 07:46 PM
Action4478's Avatar
Action4478
Action4478 is offline
Considering my experience with diesels, I don't have a clue where to start looking for the lopey start.
The PCM is trying to control the idle with incorrect info. You can start by unplugging the ICP sensor & look for oil leaking from it . Try starting it with the ICP unplugged . If its an auto , try starting it in neutral (TRS) issue . May also be a sticking IPR . Get it on a good scanner & post the live data. We can take it from there .
  #48
Old 10-30-2015, 10:02 PM
finallyo3gt's Avatar
finallyo3gt
finallyo3gt is offline
ICP?
IPR?
i did notice a good bit of oil in the valley between the heads when changing the fuel filter today...
I have torque app and dash command for my shelby. I also have an autel 400
  #49
Old 10-30-2015, 10:15 PM
finallyo3gt
Originally Posted by finallyo3gt
ICP?
IPR?
Oh.. i found this. http://www.trucktrend.com/how-to/expert-advice/1304dp-heui-how-high-pressure-oil-injection-systems-work
  #50
Old 10-31-2015, 08:04 AM
finallyo3gt
it will probably be monday before i can get to it. I will try starting in neutral and checking the ICP sensor. To be clear, it starts every time , with no problems. just idles very uneven. Just knowing hydraulic systems the way I do and from researching these injectors, I'm guessing something is sticking. When I start it and give it high idle it increases the ICP pressure which frees up whatever sticking and allows it to start Floating the way it should. If I do not increase the idle it's at its mechanically natural position where it wants to hang. from trying to understand the HPOP system I'm guessing that would be the IPR hanging.
  #51
Old 11-01-2015, 06:54 PM
finallyo3gt
So finally drove this thing a bit today. I'm impressed with braking. I found the stock setting on the chip. Crap this thing is a dog! Position 2 is high idle, with no other changes noticed. Position 3 it starts to wake up and is pretty driveable. Positions 4-6 are not as drastic a difference, but I think its there. Around 5 I could start to get the tires to spin a bit on a hard start.
Tried starting in neutral, no change. I'll try the ICP sensor when the rain stops.
Looking into the 6637 type mods and would love to do a down pipe, but just not in the budget right now.
I'm pretty convinced I need a EGT gauge, but oil field (my line of work) is a bit slow right now and I can't seem to find a probe and gauge for less than $200. Are the EGT gauges really that high?
KLWdesigns
Arizona Chapter
22
03-14-2009 07:01 AM
glb.thehammer
03-05-2008 08:59 PM
hwkeye27
04-05-2007 06:58 AM
jeffreystar
1999 to 2016 Super Duty
03-11-2006 08:04 PM
usmc1775
Computer Chips & Tuners
10-20-2001 05:53 PM
Quick Reply: New to the Forum, and Diesels
