New to the Forum, and Diesels
Read a few more threads, have a few questions.
Getting ready to do oil change and fuel filter change. I stumbled across several article on extended life coolants, vs conventional with SCA. I did notice my coolant looks pretty nasty. What's the general conscious?
Also been advice to run a bit of trans fluid in about every 5th tank, and have been told not to.
I've been told a bit of sea foam with the filter change (I believe in the stuff on my gassers), and been told it can make stuff gummy.
Catch me up to speed here guys?!
Everything else is a matter of opinion .( And they are all over the place ) Do what ever you are comfortable with , you will be hard pressed to hurt the motor. The general consensus its the trans is the weak point . (Auto) Clean fluid & filter & keep it cool
On the coolant, most will say use the conventional green with the SCAs. One type of extended life coolant (OAT?) is hard on the brass injector cups.
On the auto tranny fluid in the fuel, that is an old time deal before the fuel additives they have now. Personally I won't use it. If I need a fuel additive, I will use injectable 2 stroke oil for lubricity, or Howes fuel treat for anti gel. The fuel now has most of the lubricity added back into it threw additives. I wouldn't want to run seafoam in the oil for very long, as the injectors are fired by the oil, and additives to the oil seems not to be a good idea.
I was told it depends on the condition of the trans itself . ( a guess ) for most . I am running full synthetic in mine . It is not affected by temps ( Trans is new) I am running 2 mods on my trans , the cure & the TFT mod along with some mechanical upgrades .Mercon was in the last one .
I think we talked about this in another thread didn't we? It's the chemical makeup of the Organic Acids that eat away at the brass injector cups over time. At least that is what I gathered from extensive research and reading. Use Fleetcharge, which can be found at O'reillys and sometimes WalMart....or roll the dice and use an ELC if you want to. It may not do anything, but why chance it? Inj cups are very difficult to replace and can cause other damage if they fail.
#28
From what I read, just tonight. The ELC's are safe in 99 up, but may react with seals and rubber components in earlier trucks. This is as recommended by International. I gathered this info from a VERY informative thread on another board from like 2008. I can find it and post a link if you guys are interested. Conventional with SCA's is nearly always safe, but "requires more maintenance".
Based on my limited research, I'll probably just go with the fleet charge. Do these things really have a coolant filter? I saw that mentioned a couple of times. Is that an add on?
#30
Well, the PSD engine that went in the OBS trucks was designed before ELCs existed. The SD engine was built with stainless steel injector sleeves rather than brass, after the advent of ELCs. Conventional with SCA is what was in the engine when it rolled off the line. The decision is ultimately the owner's. I have yet to see any hard facts supporting either argument.
