Gear ratio
Old Aug 4, 2003 | 02:54 PM
PlainUni's Avatar
PlainUni
Gear ratio
Is there somewhere on a 96 F-150 that will tell me what the gear ratio is? Curiousity will kill you, I guess!
Old Aug 4, 2003 | 03:14 PM
90f150moneypit's Avatar
90f150moneypit
Gear ratio
On the door tag under 'axle'. It will give you a code that you can match up here.
Old Aug 4, 2003 | 04:41 PM
PlainUni's Avatar
PlainUni
Gear ratio
Thanks again for the help!
Old Aug 12, 2003 | 11:04 PM
pinellas50's Avatar
pinellas50
Gear ratio
You can also find out by looking at the tag affixed to the rearend itself from the factory. Near the end of the tag you should find a number, a couple of letters, and then two more numbers. example, 3 ng 73. This would be a 3.73 gear set.
Old Aug 18, 2003 | 11:39 AM
PlainUni's Avatar
PlainUni
Gear ratio
thanks again! I knew there had to be a label somewhere on the rear end, just in case they are swapped out.
88svt
Modular V10 (6.8l)
Jan 3, 2021 04:09 PM
Brian429
2015 - 2020 F150
Nov 23, 2016 11:51 AM
97puller
Aug 28, 2010 06:59 AM
FordGuy0131
Jan 24, 2008 01:00 PM
madman666
Jan 24, 2002 03:24 PM
