78 F100 lift kit recomendations please
i havent bought anything from these guys but from what ive read they do decent parts, the website is easy to navigate aswell which helps
1973-79 Full Size Truck/Bronco-Broncograveyard.com
with my truck ive rebuilt the engine (stroked out to 408ci)
rebuilt trans and transfer box
replaced all driveshaft uni's and twice for the rear and i blew them to bits doing a burnout.
fitted new front springs
retro fitted a blade fuse holder under the dash to get rid of the ****ty ceramic fuses
started with tidying up the wiring in engine bay and fitting fused relays
if theres anything i can help with hit me up
I think it was a good price. Does need a bit of work but then it is nearly 40. Just trying to get info on it. I've ordered a chiltin manual, so waiting to see if it varies much being that it's an Aus assembled. Ive got a leak in the steering box to fix for a wof as well as play in the steering column. By the look of it the steering column is from an xa falcon. Those are all that's holding it back for a wof. The body needs a tidy up, which isn't to major and also the gearbox crunches into second. So the plan is to get the wof then pull motor and box out and rebuild gearbox. Paint the motor and then sort bodywork. I'm gonna order some cragars from the states as well as a lift kit and do that after body work. I'm gonna look for a standard bumper and take that bull bar off. You keen on it?
jschne52
10-18-2011 07:39 PM
BigTex68
26
05-07-2011 12:02 PM
78'fordtruckguy
11-27-2006 05:56 PM
