Sponsored by: Real Truck
headlight wiring
Old Oct 27, 2004 | 09:08 AM
RobertH's Avatar
RobertH
Talking
I just received the Universal Headlight wire harness from suvlights and installed last night and included the tip from northtexaspowerstrokes website for the diode and all I can say is WOW! When driving in to work early this am, clicked on the brights, and the hills/curves looked like daytime. I thought I was in an airplane coming in for a landing with the landing lights on!
My thanks to those in the websites for publishing this knowlege so we can improve out rides!
Now with the 9007 Silverstars, the upgraded 9005's in the foglights, and when I click on High beams, the lows stay on, and the fog's stay on.
Did the other mod to cut the green wire with yellow tracer and ground it per other references on this site.
Old Jul 15, 2005 | 11:42 PM
nhancock's Avatar
nhancock
RobertH and Higa2000,
If you guys are still around, could you describe the diode mod from the northtexaspowerstrokes site. I installed an upgraded harness tonight and would like to perform the mod to keep the high/lows on at the same time. They've changed their site around and the link is no longer good.
Thanks,
Neil
Old Jul 16, 2005 | 10:41 AM
Steve_250's Avatar
Steve_250
Just a thought, did you upgrade to the Silverstars?
Headlamps and fogs? (9007ST & 9005ST)
I did and also used the heavier harnesses from summitracing.
The lights will work with the stock wiring but are brighter with the heavier harness.
Old Jul 16, 2005 | 06:10 PM
nhancock's Avatar
nhancock
I did upgrade to the Silverstars a while back. I think part of my problem is the alignment. All the inspection shops that are supposed to have the equipment around here, either don't know how to use it, or it's broke.
I pulled up to a wall last night and did some tweaking and it helped. But I noticed when I was driving last night, when I held the lever back and activated the highs and lows at the same time, it was exactly what I needed.
Thanks for the thought.
Neil
Old Jul 18, 2005 | 06:22 AM
nhancock's Avatar
nhancock
Found the updated link.
http://www.northtexaspowerstrokes.co...pgradeharness/
Old Jul 18, 2005 | 07:47 PM
RobertH's Avatar
RobertH
nhancock, glad you found it. Thanks to Big K for re-posting it. You beat me to the punch. I thought I had saved it before and was gonna send it over to ya, but I just had a hardcopy. Good Luck 'cause his instructions led me to the best headlight mod I could have. They are great!
Old Jul 18, 2005 | 07:59 PM
Steve_250's Avatar
Steve_250
Summit racing has the good harness for 40 bucks.
They also have the Sylvania Silverstars 9007 headlamps for half price, $22.50.
Old Jul 18, 2005 | 08:29 PM
nhancock's Avatar
nhancock
Just got back from testing it out. It's awesome. No more dim country roads!
Best $.69 I ever spent at Radio Shack.
Old Jul 18, 2005 | 08:35 PM
nhancock's Avatar
nhancock
Just had a thought. I wonder if anyone has ever run a harness to the fog's to make them brighter?????
Maybe something to try another day. I'm happy for now.
Old Aug 2, 2005 | 07:56 PM
Grannygear's Avatar
Grannygear
Rod and Robert H
On what year and model vehicle did you install the harness from SUVLIGHTS? There website recommends a double harness on vehicles with dual batteries like the Super Duties. Did you install the single harness or the double harness? Do you clip the diode into the connector or does it have to be soldered?
Robert H - What is the other mod you referred to involving cutting the green wire with yellow tracer and ground it per other references on this site?
Thanks for any help you or anyone else can provide.
Randy
Old Aug 2, 2005 | 10:09 PM
AzBaddBoy's Avatar
AzBaddBoy
No need to spend $95 bucks on anything. Everything mentioned here can be done with some wire and relays. Get your stuff from http://www.partsexpress.com/webpage....7&WebPage_ID=3
They have your relays and plugs for them so it looks professional. If you don't know much about electrical and relays. Save yourself the hassle and buy the premade kits. Otherwise it shouldn't cost more than $10 for everything.
Old Aug 3, 2005 | 09:15 AM
nhancock's Avatar
nhancock
Grannygear,
I think the harness works with any year that uses the 9007 bulb.
I used a single harness. If you use a dual, the diode option may not work, because you'll be using both factory harnesses. I may be wrong about that.
I just put the diode in the empty passenger harness and taped it up.
Old Aug 3, 2005 | 08:23 PM
  #28
RobertH's Avatar
RobertH
Grannygear, I just followed the instruction on the http://www.northtexaspowerstrokes.co...pgradeharness/ web site for the harness and diode installation. Took a little re-reading to understand it and when i got the harness in, it started to make more sense to me.
It has been a long time since I did mine, so don't remember all the details outside of what is in the link.
The fog light references I used was: https://www.ford-trucks.com/forums/s...hreadid=201800
and http://www.ssdiv.com/fogfix.html in which this last one is the mod that I used for my 2002 Excursion.
Old Aug 3, 2005 | 11:57 PM
  #29
johnw's Avatar
johnw
anybody know the web address for brite box? john
Old Sep 19, 2005 | 03:42 PM
  #30
blueeyes2478's Avatar
blueeyes2478
Originally Posted by BlueZack
OK. I have remembered how this wiring works. You can do it for around $30.00 give or take. You need a 12v 30amp relay from radio shack, an inline fuse, wire splicers, crimp on connectors, and a roll of 14gauge wire. You tap into the high beam wire at the headlight and wire it to one side of the coil on the relay. You run a ground wire to the other side of the coil. You run a wire from the hot side of the battery to the 12v in on the relay. You tap into the low beam wire and wire it to the 12v out on the relay. I did it on the passenger side so the wires did not have to be long. Remove the battery and you can reach everything easily. I mounted the relay on the ground screw close to where the battery sits. It works perfectly, and I assume is the same set up as the brite box, only you do the wiring and save some cash.
Does anyone know if there is any problem in doing this mod.I was thinking that there would be when u pull the head light switch twards u,when your low beams are already one.Also would like to hear how people that have done this mod,on how they feel about it.I really like the idea of having both head lights on,but dont want to cause damage to my truck either.
