Sponsored by: Real Truck
no heat
Old Oct 8, 2015 | 07:43 AM
sherifflittle's Avatar
sherifflittle
no heat
ive got a 04 6.0 super duty and it will not put out any heat unless the rpms are above 1000. does this mean a clogged heater core or something else. thanks
Old Oct 8, 2015 | 11:00 AM
Chuck's First Ford's Avatar
Chuck's First Ford
check both large radiator hoses... are both HOT... 1 will be hotter than the other...
next is the heater hoses.. same thing.
remove radiator cap.. can you see the water flowing....?
have you had the cooling system reversed flushed?
thermostat replacement!!!
water pump replacement
lower part of radiator blocked...clogged...
lots of things before heater core issues.
Old Oct 8, 2015 | 12:04 PM
droldsmorland's Avatar
droldsmorland
How about the fluid level...have ya checked it?
Old Oct 8, 2015 | 02:42 PM
Chuck's First Ford
YES, that also.
Old Oct 9, 2015 | 03:12 PM
sherifflittle
yes the fluid is full. guess ill go with the reverse flush after i check the hoses. thanks.
Old Oct 9, 2015 | 03:26 PM
POS Camaro's Avatar
POS Camaro
Mine did the same thing last year. It was a broken water pump. Truck would heat to about 213F and cool down but there was no heat. Impeller broke from the shaft.
Old Oct 10, 2015 | 03:12 AM
sherifflittle
doubt its the water pump because it puts out great heat when rpms above 1000.
Old Oct 10, 2015 | 06:28 AM
projectSHO89's Avatar
projectSHO89
Jumping to that conclusion is premature. A worn or eroded impeller will do exactly what you described (as well as can numerous other things).
Do your DIAGNOSTICS before deciding what remedial action to take.
Old Oct 10, 2015 | 07:16 AM
Chuck's First Ford
just so you know..
I have replaced water pumps with the impellor blades missing 75 percent of blade GONE. not 1 blade, but all of them.
test, inspect, troubleshoot... do it Correctly.. cheaper at the end.
Old Oct 12, 2015 | 03:30 PM
droldsmorland
How many miles on the clock? Ill bet its time for a flush anyway. A full system flush should be performed according the the schedule in the owners manual or sooner. My bet is its never been done. Time for an inspection. Replace the T-Stat with a Motorcraft part only. Then while the systems down pull the pump and inspect. Also consider replacing any hoses that look/feel questionable.
Old Oct 12, 2015 | 08:23 PM
KW7DSP's Avatar
KW7DSP
That would be my first clue the Water Pumps is toast
Old Oct 14, 2015 | 04:29 PM
sherifflittle
160,000 miles on the clock.still have to check hose temps.just been really busy.thanks for all the responces.
Old Oct 14, 2015 | 07:55 PM
98SurplusExpy's Avatar
98SurplusExpy
Assuming your operating temps are good (you didn't say) ... I'd suggest checking your vacuum pump. The diverter valve may not be "diverting" when you select warm on the dash.
Old Oct 18, 2015 | 05:16 PM
sherifflittle
op temps are good. will put out heat when driving just not when idling.
Old Oct 20, 2015 | 09:26 AM
sherifflittle
ok i checked hoses and top and bottom heater hoses are nice and warm. with heater on one of the heater hoses is real warm and other is just kind of warm. i did notice a slight smell of antifreeze and saw some steam and bubbling from around the cap. does this help with the diagnosis? may just take it to the shop and have it checked.
