Efuel no start
Old Oct 7, 2015 | 09:50 AM
voodoosmooth's Avatar
voodoosmooth
Efuel no start
I just got done installing an efuel system in my 97 PS. Pump is coming on and I'm getting 70 PSI fuel pressure and no leaks. I also did the fuel bowl delete and realized that I forgot to connect the IPR connection. I connected it last night and tried to start her up but not getting there. It's like it's not getting fuel.
Any thoughts on what I might be missing or what to look for?
Thanks for the help in advance.
Old Oct 7, 2015 | 11:19 AM
pilgrimbizket's Avatar
pilgrimbizket
My truck took forever to get primed after I did e fuel. Make sure both your fuel filters have fuel in them if they do not already you might as well go and remove them and filling up with fuel and try starting the truck after that.
Old Oct 7, 2015 | 11:38 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
I ran my pump for probably 5 minutes until I could stop hearing the gurgling sound
Old Oct 7, 2015 | 11:46 AM
voodoosmooth
I filled the filters up before even trying to start the truck. Pressure was good enough to blow the original fuel return line (just replaced it from Dieselorings.com) . Should I be looking at the ICP or IPR?
Old Oct 7, 2015 | 12:33 PM
madpogue's Avatar
madpogue
Can you get the truck on AutoEnginuity or the like?
Old Oct 7, 2015 | 12:55 PM
voodoosmooth
Unfortunately I don't (but I'm looking to get one, they look sweet). I have a normal OBDII scanner but it's not going to show me pressure ranges like the system you refer to.
Old Oct 7, 2015 | 01:22 PM
Hussler's Avatar
Hussler
Is the connector that was on the passenger side of the fuel bowl plugged into the main wiring harness? Also is this a DIY system or a purchased kit?
Old Oct 7, 2015 | 03:36 PM
voodoosmooth
Yep, harness is plugged in. I'm using the fuel bowl heater wire to start the relay for the fuel pump. I'm turning the key on, pump comes on, wait to start is working, then it turns over like a beast, just doesn't seem to be getting the fuel.
Oh, it's Mark Fugazzoto's system (which is a sweet setup I have to say!). For the connections I used the Strictly Diesel OBS Fuel System Harness.
Old Oct 7, 2015 | 04:14 PM
Hussler's Avatar
Hussler
Without numbers I would be guessing. I would certainly recheck the IPR connector and make sure the wires are not mushy / melted. If you were cranking a lot before reconnecting the IPR might want to check the HPOP reservoir and top it off with oil.
Old Oct 7, 2015 | 05:30 PM
Action4478's Avatar
Action4478
I'm not convinced the IPR is getting voltage & ( or ) ground . Especially since the IPR gets ground from the PCM .
Old Oct 7, 2015 | 06:06 PM
voodoosmooth
I know the connector looks worn and I may not have a good connection. I'm thinking that I'm just going to get the replacement plug kit from DieselOrings for $10.00 and redo the connector.
I'm going to take a look when I get home.
Old Oct 7, 2015 | 06:48 PM
rusty1161's Avatar
rusty1161
The IPR and EBV connectors are exactl the same. Confirm they did not get switched.
Also, my IPR connector had both wires bare copper inside of the split loom, led to a no-start. Pull the split loom back and inspect it thoroughly.
Rusty
Old Oct 7, 2015 | 08:27 PM
Action4478's Avatar
Action4478
You had to cut some wires for the E fuel . Make sure you cut the correct ones . I wasn't aware the fuel heater was on full time .
Old Oct 7, 2015 | 08:41 PM
voodoosmooth
Woot! It was the IPR connector. I pushed on it and wiggled the wire. She screamed to life! Ran great!. New wicked wheel 2 sounding good. Idle sounds so much smoother!
I'm going to order the new connector and replace this one for sure.
Thanks you to everyone for your help!!!!!!
Old Oct 10, 2015 | 10:44 AM
voodoosmooth
Sorry to bother everyone. I have another question/issue.
When I turn the key on to get the Wait to Start and the fuel pump going, I wait and then try and start the truck. It takes about 10 seconds of cranking before it will start. I watch the Oil Temp gauge on the dash and as soon as it kicks over the truck will start. Does anyone know why I would have a delay? Seems I'm not getting oil pumped for a bit.
I checked oil in the truck and I'm good. I haven't opened the HPOP reservoir yet, but was thinking I didn't have to?
