dana 60 gears?
Old Aug 4, 2003 | 10:09 AM
powerram50's Avatar
powerram50
dana 60 gears?
i have heard you cant fit 4.1 gears or higher in a dana 60 that was made with 3.56 gears or smaller.but what can i go to my truck has stock 3.73 gears.what gears can i go to i want at least 4.56 or higher do i nead a whole new axle?
Old Aug 4, 2003 | 06:22 PM
1976 ranger's Avatar
1976 ranger
dana 60 gears?
The carrier you have now will only take a 4.10 ratio or lower (3.07). If you want to run 4.56 or higher you have to find a 4.56 and up carrier.
David
Old Aug 5, 2003 | 08:22 AM
BigFootnHawse's Avatar
BigFootnHawse
dana 60 gears?
My front D60 had 3.55s with an open carrier. I recently regeared it to 4.88s reusing the carrier. I believe they call it the "thick gears" that can run with the shorter ratio carriers. Verify this with a gear company, but that is what I did.
