Help!!! injector wiring
Old Oct 4, 2015 | 02:47 PM
arkredneck's Avatar
arkredneck
So I'm trying to swap over to super duty valve cover gaskets and I cut one wire at. Time and did my splices was careful didn't think I messed up and now truck won't start won't even try to fire.
Old Oct 4, 2015 | 02:50 PM
arkredneck's Avatar
arkredneck
Only code is p0603
Old Oct 4, 2015 | 03:03 PM
farmert's Avatar
farmert
As I'm sure you know the OBS plug is laid out as GP-I-C-I-GP, the
superduty plug is laid out GP-GP-I-I-C-I-I-GP-GP. If you wired the superduty plug like the OBS plug you can see the problem.
Old Oct 4, 2015 | 03:04 PM
sean9049's Avatar
sean9049
thats the keep alive memory(kam) code, did you disconnect your batteries? if yes thats more than likely where the code came from. did you use butt connectors or solder the wires? just a little more info to get out of you... truck turns over but doesnt fire correct? is it cranking really slow/normal? you did reconnect the glowplug and injector connectors right? all of the connectors to the VC gaskets are plugged in and locked? double check your work thoroughly. not trying to put you down or sound mean its just easy to forget the simple things.
Old Oct 4, 2015 | 03:12 PM
arkredneck's Avatar
arkredneck
I was aware of the differences between the obs and superduty wiring and swapped it. The only thing I did do was take the 2 commons on the obs and tied them to the 1 common on the superduty
Old Oct 4, 2015 | 04:56 PM
arkredneck's Avatar
arkredneck
I'm at a lost I did a buzz test and got a p1111 code
Old Oct 4, 2015 | 05:03 PM
arkredneck's Avatar
arkredneck
Sorry guys I'm an idiot the ipr harness got unplugged it started
Old Oct 4, 2015 | 05:17 PM
sean9049's Avatar
sean9049
Yay! see its the little things you overlook that get you.
Old Oct 4, 2015 | 05:36 PM
Action4478's Avatar
Action4478
I can't help wondering how ?
Old Oct 5, 2015 | 10:21 PM
arkredneck's Avatar
arkredneck
I really don't know how it happened
Old Oct 6, 2015 | 06:52 AM
pilgrimbizket's Avatar
pilgrimbizket
Didn't you take the whole harness out of the truck to solder the wires?
Old Oct 6, 2015 | 12:27 PM
cowmilker08's Avatar
cowmilker08
IPR harness unplugs at the fuel bowl.
Old Oct 7, 2015 | 07:40 PM
arkredneck's Avatar
arkredneck
My truck has electric fuel and the ipr harness is what's left of the due bowl wiring harness and the clip that holds it together broke so I guess I bumped it and unplugged it
Pigpen1
16
Feb 8, 2019 07:52 AM
2003bigred
1997 - 2003 F150
Jul 20, 2018 06:44 AM
hodges710
Aug 11, 2012 08:35 PM
Dually77
60
Jan 31, 2008 01:39 PM
big315
24
Nov 30, 2007 08:21 PM
