5.4 dead
Old Oct 3, 2015 | 07:41 PM
chrismcfreely's Avatar
chrismcfreely
5.4 dead
I have a 2001 xl 7700 bifuel rwd truck with 137,000 miles. The engine is toast, and I am trying to figure out what to do next. I am thinking about putting in a regular, non bifuel, 5.4. I have never done an engine swap, but have time to figure it out. I am pretty sure the ecu and wiring is different, and am wondering if buying a vin L ecu with a remanufactured 5.4 would work out. My truck has the 4r100 transmission. Is this doable? I would consider a 4BT instead, but here in Maricopa county AZ they do emissions testing, and don't know if it would be legal. Scrapping the truck is also an option, but I have done a lot of work to it in the past couple years. Anybody know the easiest solution to this p.i.t.a.?
Old Aug 28, 2019 | 08:53 PM
mark0206's Avatar
mark0206
The donor motor I want to swap with is pulling P0022-ff and P022-00. 2008 F250 Super-Duty 5.4L 3v...Do these codes mean trouble??
Old Aug 28, 2019 | 09:42 PM
85e150's Avatar
85e150
Welcome to FTE.
Looks like your codes are off. Yes, they are trouble. Check them again, and go here:
https://www.obd-codes.com/p00-codes
Anything to do with camshaft position has to be fixed, and it's a technical job, and probably requires special tools and a bunch of parts, like the entire chain, tensioner, sprocket set up. Maybe. Or just cam phasers.
Old Aug 29, 2019 | 09:48 PM
mark0206's Avatar
mark0206
HELP !! LIMP MODE !!
Originally Posted by 85e150
Welcome to FTE.
Yeah...I understand...Ive done alot of research and I know it could be alot of different things. Probably entire timing kit and then STILL selenoids and vvt...vct...etc. Its just that my engine is locked and I have an opportunity to buy a 5.4l 3v for $500.00. But it is pulling po022 code. timing rertard problem. Could I fix it by doing timing? Not sure what to do?? The previous owner got a new engine. He said this one started right up but would go into Limp Mode at higher RPMS...Also I was wondering if my locked motor may have locked to timing chain slippage (jumping Gears). Is that possible?? I havent opened it up yet to check....THANKS
Old Aug 29, 2019 | 11:14 PM
85e150's Avatar
85e150
Swapping in a different motor is going to cause issues. I take it you have a 2 valve motor now, right? If that $500 motor has issues and doesn't match your motor, forget it.
Your motor could be locked due to timing chain issues. Only a tear down will tell.
I've seen a few threads here with people trying to swap different mod motors.
If your truck is a keeper and otherwise sound, consider spending a bit more for are rebuild or waiting until you get an exact match on a used motor.
Old Aug 29, 2019 | 11:33 PM
mark0206's Avatar
mark0206
Yes...It IS an exact match...both Motors are 5.4L 3V ford f 250 super duty...This guy just wants this motor out of his way..so..500 bucks. He showed me the history on the scanner. It was just pulling a P0022 code...also...supposedly... the previous owner already did a complete timing kit job on it about a year ago. I think I better grab this motor..!! Now, Im wondering if I should try to install it myself (tight budget) or pay a shop $1200.00 to install it!! Tks for the reply.. If Im REAL LUCKY maybe it only needs VCT Bank 2 Solenoid replacement!!! What do ya think !!
Old Aug 29, 2019 | 11:37 PM
mark0206's Avatar
mark0206
I want to get into my motor first tho. Ive been told that a timing chain cant lock a motor and also that it can. Im thinking if that chain was "slopping" around in there it may have jumped up and got caught on the cam shaft sprocket and now motor wont turn. I put a Pry Bar and extension pipe on that sucker and tried to turn (both directions) NOTHING..WONT BUDGE...2008 F 250 SUPER DUTY...5.4L 3V...
Old Aug 30, 2019 | 12:05 AM
85e150's Avatar
85e150
OK, yes, if it's a match and otherwise a runner, I think you can clear those code problems without having to rob a bank.
Moon's 01f250
Engine Swaps
May 2, 2017 07:38 PM
bubahyde
1997 - 2003 F150
Jun 5, 2015 05:38 PM
Apocalypse
Mar 28, 2013 12:55 AM
robbhorn
2004 - 2008 F150
Feb 27, 2013 09:22 PM
lariatrider
Engine Swaps
Jul 3, 2004 09:13 AM
