OBD2 port power problem
Old Oct 1, 2015 | 09:07 PM
RBerry9511's Avatar
RBerry9511
I was wondering if there is a fuse or something that can stop the OBD2 port from getting power. If there is where is it on a 2000 limted 4x4 7.3L. Please help. Thanks in advance.
Old Oct 1, 2015 | 11:21 PM
ExxWhy's Avatar
ExxWhy
The fuse for the cigarette lighter also runs the OBD port, at least on the V10 version.
Old Oct 1, 2015 | 11:25 PM
RBerry9511's Avatar
RBerry9511
Thanks I will check that and see if it fixes the problem. I guess I should check all my fuses anyway......just to be on the safe side.
Old Oct 1, 2015 | 11:37 PM
Stewart_H's Avatar
Stewart_H
Yes, there is.
Go to the Excursion Tech Folder sticky thread. The very first links are for the Owners manuals.
Stewart
Old Oct 1, 2015 | 11:43 PM
RBerry9511's Avatar
RBerry9511
Thanks for the help Stewart . I was a little frustrated when I posted. I teally need to relax before I post something that I really should have been able to figure out. you guys are the best for helping out even when I am being less than patient .
Old Oct 2, 2015 | 01:28 AM
KW7DSP's Avatar
KW7DSP
Yep. The Cigarette Lighter Fuse is also the OBDII Port Power. Go Figure.
Old Oct 2, 2015 | 07:28 AM
ExxWhy's Avatar
ExxWhy
Not the smartest configuration since that is the #1 most likely fuse to get blown.
Old Oct 2, 2015 | 08:50 AM
Magnus E's Avatar
Magnus E
Had this happen last year on mine - cannot recall which fuse location it was unfortunately.
Old Oct 2, 2015 | 10:28 AM
RBerry9511's Avatar
RBerry9511
Verified cigarette lighter is not working. I am off to go get fuses.
Old Oct 2, 2015 | 01:42 PM
Immortal_Ben's Avatar
Immortal_Ben
You do not keep fuses in your truck? I sure do!
Old Oct 2, 2015 | 02:06 PM
az_r2d1's Avatar
az_r2d1
Yep, it's the cig lighter fuse. Dumb but.. easy fix.
Experienced the exact same thing when testdriving an ex a couple years ago and wanting to hook up my scanner to the OBD2 port.
Old Oct 2, 2015 | 02:25 PM
Bently_Coop's Avatar
Bently_Coop
I bet he will now. After mine went out I have a large pack of fuses in the glove box.
Old Oct 2, 2015 | 07:47 PM
RBerry9511's Avatar
RBerry9511
You are absolutely correct. I went and got a large 40 fuse pack that fits very well in my centet console. I will be switching the fuse out as soon as I finish a few things around the house. I will update as soon as it is fixed.
Old Oct 2, 2015 | 08:14 PM
Immortal_Ben
Having worked and lived out in the boonies and oil fields, you gotta be able to self-recover, especially with simple things like fuses.
Old Oct 2, 2015 | 08:31 PM
Psyclopse's Avatar
Psyclopse
I've noticed with my project Ex (knee deep in wiring) that there are quite a few circuits that share fuses that really have no logical reason to be doing so. The thought has crossed my mind more than once to just rewire the whole thing my way. The only thing that stops me from doing so is that I'd have to rewire the dash as well- and there really isn't nothing wrong with my dash harness.
