Offroad & 4x4
33 inchers?
Old Aug 4, 2003 | 01:43 AM
loui6035's Avatar
loui6035
33 inchers?
hey i have an 89 f-150 with a 3 inch body lift i was wondering if 33 by 12.5 would fit. please someone let me know. thanks alot
Old Aug 4, 2003 | 04:35 AM
13hondacr250's Avatar
13hondacr250
33 inchers?
95 150 with a 3 inch body lift. I'm running 33x12.5's. Had to trim the front bumper bottom egdes just a tad but no rub anywhere else. Our bodies are very similar so I'd take a stab to say it should work. But if you have wheels with improper back spacing it can cause tires to rub.
Old Aug 4, 2003 | 11:39 AM
MustangGT221's Avatar
MustangGT221
33 inchers?
It would only rub on the radius arm at full turn which isn't that bad. Just don't turn the wheel all the way. Other then that it'll fit.
Old Aug 4, 2003 | 05:32 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
33 inchers?
Yes they will fit. They will rub the radius arms while turning. Custom radius arms aren't very expensive. I was quoted 75 a piece. Can't decide wether or not to order them.
Old Aug 4, 2003 | 09:02 PM
93_F150's Avatar
93_F150
33 inchers?
I've got 33x12.50 Dunlop Mud Rovers with leveling springs on my '93 f-150. They don't rub anywhere, even at full turn. Just my experience.
Old Aug 4, 2003 | 09:40 PM
13hondacr250
33 inchers?
Back spacing on the wheels, Back spacing. I have no rub.
Old Aug 4, 2003 | 11:50 PM
MustangGT221
33 inchers?
I have skyjacker radius arms with the bend to help prevent the rub. I have 15 by 10" wheels with 35/12.5" tires and 3.62" backspacing, rubs but not too bad.
Old Aug 6, 2003 | 03:54 AM
MEPR's Avatar
MEPR
33 inchers?
im running 33x10.50 swampers whith stock back spacing and i just catch my radius arms at full lock whith the longer lugs. If you get another couple of inches of back spacing you will be fine.
Da boyz
Jan 12, 2015 07:52 AM
93f250tn
Mar 1, 2010 08:30 AM
JTD1972
May 23, 2004 12:05 AM
TylerG
Bronco II
Apr 29, 2004 12:35 AM
debayfishing
1978 - 1996 Big Bronco
Jan 1, 2004 04:37 PM
