Bumpers? Anyone?
Old Sep 29, 2015 | 03:17 PM
84&04's Avatar
84&04
Bumpers? Anyone?
Be gone through just about every thread on here. Doesn't seem like anyone has made a good DIY bumper? Anyone?
Doesn't seem like any company's make them either, aside from those godawful warn bumpers I keep seeing.... Any bumpers fit these old trucks?
1985 f250
Old Sep 29, 2015 | 04:30 PM
Tuckering's Avatar
Tuckering
I have a student in my welding class using this site as a guide.
Redneck Bumper Build !!! Winch bumpers for all!
Old Sep 29, 2015 | 11:30 PM
The_Josh_Bear's Avatar
The_Josh_Bear
Oh man that's sick! Love it!
Old Sep 30, 2015 | 08:00 AM
tjc transport's Avatar
tjc transport
i ain't rite
i like the K. I. S. S. approach:
8 inch channel steel i got for free from a warehouse we were tearing down.
Old Sep 30, 2015 | 11:08 AM
84&04's Avatar
84&04
Originally Posted by tjc transport
i like the K. I. S. S. approach: 8 inch channel steel i got for free from a warehouse we were tearing down.
looks like I'm gunna pick me up some channel! Hahah perfect! I had considered it, but I wasn't too sure on how it would look! Too bad our mounting points are different! Yours would be the perfect cheat sheet!
Old Sep 30, 2015 | 11:09 AM
84&04's Avatar
84&04
I have a student in my welding class using this site as a guide. Redneck Bumper Build !!! Winch bumpers for all!
i saw that one! I'm just more of a fan of the, "go ahead and cut me off I'm insured" bumpers. Mad max style hahah
Old Sep 30, 2015 | 11:17 AM
tjc transport
i ain't rite
mine is so overbuilt i have used it to push start mack trucks.
not only is it connected to the frame with the four bolts on the side, it is also connected with the straps the tow hooks are connected to on top, and the hitch receiver on bottom is bolted to the frame 14 inches in. if i remember correctly, it is connected to the frame and snow plow mount with over 18 different bolts at 10 different spots.
in reality though it is simply 3 pieces of channel. the front piece, and the two sides cut at a 22 degree (i think) angle to return the sides back towards the tires a bit, and 2 pieces of angle iron welded on to connect it to the sides of the frame rails.
you can see the angles a bit better in this pic:
Old Sep 30, 2015 | 11:21 AM
84&04's Avatar
84&04
mine is so overbuilt i have used it to push start mack trucks. not only is it connected to the frame with the four bolts on the side, it is also connected with the straps the tow hooks are connected to on top, and the hitch receiver on bottom is bolted to the frame 14 inches in. if i remember correctly, it is connected to the frame and snow plow mount with over 18 different bolts at 10 different spots. in reality though it is simply 3 pieces of channel. the front piece, and the two sides cut at a 22 degree (i think) angle to return the sides back towards the tires a bit, and 2 pieces of angle iron welded on to connect it to the sides of the frame rails. you can see the angles a bit better in this pic:
Yeaaaah. It's beyond perfect! I'll have to copy you bahahah, sadly the hours at work are plentiful... Bad for my sleep, great for my bank... Soon. Soon I will steal your bumper TJC! Haha
Any idea what gauge the c channel is?
Old Sep 30, 2015 | 11:41 AM
tjc transport
i ain't rite
THICK, and heavy too!!!
it was part of a pallet rack frame.
if i remember correctly it is 3/8 thick and weighs around 100 lbs.
takes 3 people to take off/put on. 2 to hold it up, and one to run at least 2 bolts in to hold it up.
Old Sep 30, 2015 | 12:05 PM
sjwelds's Avatar
sjwelds
8" standard channel is 11.5 lbs per foot, with a .220" web thickness. My steel book shows two sizes thicker. Then there is what they call ship/car channel, which would be 18.7 lbs per foot, with a .353" web thickness.
Old Sep 30, 2015 | 01:58 PM
84&04's Avatar
84&04
THICK, and heavy too!!! it was part of a pallet rack frame. if i remember correctly it is 3/8 thick and weighs around 100 lbs. takes 3 people to take off/put on. 2 to hold it up, and one to run at least 2 bolts in to hold it up.
sounds fantastic!!!!!
84&04's Avatar
84&04
thanks sherwin!
Old Sep 30, 2015 | 02:04 PM
84&04's Avatar
84&04
Well, found some on Craigslist, which is fantastic, 55x2x8x1/4 30$ thank you so much TJC! You're my hero currently haha
Old Sep 30, 2015 | 03:22 PM
sjwelds's Avatar
sjwelds
I'd sell it to you for $6.50 a foot, brand new.
Just sayin'
Old Sep 30, 2015 | 03:25 PM
ghunt's Avatar
ghunt
I'd like to build a bumper for my Ranger, the flimsy plastic front one is a joke and the rear one isn't great either, but with such a small truck I can't have something that weighs a ton. I work with autocad as my job, I might see if I can draw up something, order a sheet of diamond plate 1/8" steel from a local fab shop and see if they can cut it out on their CNC table so I can work on it at home. I used to do plate steel fab drawings all the time so it shouldn't be too difficult.
