Shake when towing
Old Sep 29, 2015 | 07:58 AM
ALAN_50501's Avatar
ALAN_50501
Shake when towing
I have a small 5X8 flatbed trailer I use to haul my riding lawn mower, when I drive it on highway at 55 to 60 mph I feel a shake in steering wheel...my truck is a 2008 with 5.4 and does have a tonneau cover..will having this cover box cause shaking?
Old Sep 29, 2015 | 08:48 AM
FX4ALL's Avatar
FX4ALL
Does it shake without the trailer?
Are the tires on the trailer balanced?
Old Sep 29, 2015 | 11:51 AM
senix's Avatar
senix
This points to a trailer problem.
If no shaking without the trailer then the trailer is the issue.
You could try to rotate the tires or see if the can even be balanced.
How old are the tires? Check the tread to see if there are issues with separation?
Old Sep 29, 2015 | 03:57 PM
ALAN_50501's Avatar
ALAN_50501
Tires on truck are brand new less then week old.. only time it shakes is when u have trailer hooked
Old Sep 30, 2015 | 12:31 PM
FX4ALL's Avatar
FX4ALL
The trailer tires, are they balanced? ...wheels on the trailer bent / out of round? ..axles bent?
Old Oct 2, 2015 | 07:20 AM
Slowpoke Slim's Avatar
Slowpoke Slim
It's nothing to do with your bed cover. Something is wrong with your trailer. Are you sure it's not just bouncing around over rough roads? I see a lot of guys towing these little trailers down the road fast and they bounce all over the place.
Old Oct 2, 2015 | 07:39 AM
RV_Tech's Avatar
RV_Tech
You could verify it is the trailer by asking a friend to tow your trailer with their truck. Do the trailer tires suggest anything is out of line or bent by the look of their tread?
Steve
Old Nov 1, 2015 | 12:19 AM
Kevin Kanzler's Avatar
Kevin Kanzler
Is the trailer loaded well? It's small and light but even then negative tongue weight can cause quite and issue. Also too heavy on one side or another can effect. Do you have a solid hitch? Some of the 3 ball ones, if not adjusted, have play in them.
Old Nov 1, 2015 | 05:44 AM
Chuck's First Ford's Avatar
Chuck's First Ford
I guess He missed the above statements of check the TRAILER tires/wheels...
not the Truck tires.
Redrockerstl55
All Things Towing
16
Jul 27, 2018 04:22 PM
djm1204
All Things Towing
17
Nov 26, 2014 02:58 PM
ag-ford-4x4
All Things Towing
24
Jan 29, 2007 12:19 PM
eigenvector
General Automotive Discussion
Oct 25, 2006 11:51 PM
67f100
All Things Towing
Nov 11, 2005 10:06 AM
