Runs hot when using electrical
Old Oct 5, 2015 | 08:25 AM
c2z4s9's Avatar
c2z4s9
Originally Posted by kr98664
Any progress yet? I got to thinking. Don't worry, it's just social thinking and I can stop anytime I want...
No problem. I apologize that I'm being a little slow. The truck isn't my daily driver and I have a few other vehicles with issues so I've been forced to prioritize. With that said I did do a little troubleshooting. I'll try to answer your points with the testing I have done.
Fault #1: Verify the alternator DC output is within specs. If low, and the battery is marginal, this would cause a weak spark and the rough running you noticed right away with the lights on and heater fan on high. A fresh, fully charged battery would mask the low system voltage for a few minutes until the battery ran down. That's why I'm now thinking a tired old battery may be part of the fault, in addition to an alternator issue. How old is the battery? If you can repeat the rough running, monitor the DC voltage while it's happening. The rough running may not have anything to do with AC ripple. Or if the battery is good, it may have just been partially discharged due to low charging voltage from a bad alternator
I checked the DC output of the alternator with a meter and then I did put the oscope on it also. However, I honestly wasn't paying very close attention to the actual charging voltage. I can confirm that there is no excessive ripple on the output -- as long as the ground is properly connected (of course). Meter reads 0 AC and the scope shows the same. Of course if the scope probe is floating then I see the rise and fall of the generator, something like 12 Volt swing (this is peak to peak). I took a picture but I don't have it with me so the voltage I report isn't very accurate. Now with all that said I didn't pay any attention to what the actual DC voltage was, so I will have to go back and check that sorry. The battery is old. I have never replaced it, so it is certainly suspect.
Fault #2: The 2 erratic gauges could be caused by AC ripple passing through the IVR, or an IVR fault itself. (More on the third gauge next) Investigate the rough running first by monitoring the DC voltage, and then turn your attention to the gauges. Actually, you can do some preliminary troubleshooting of the gauges by checking for AC ripple at the alternator while monitoring the DC output. It's fairly common for an alternator with low DC output to also have high AC ripple, but few people have reason to check for it, so it typically goes unnoticed.
As I said before I didn't see a lot of ripple, but I would still like to check (with a scope) at both the input and the output of the regulator, but I haven't ripped apart the dash yet so that may have to wait until this upcoming weekend. This could certainly still be a bad regulator.
Fault #3: This is what really had me stumped. Why are only 2 of the 3 gauges acting up? I was doing lots of mental aerobics, picturing electrons zipping here and there, and nothing made sense why if you had 3 functioning gauges, only 2 were erratic. Then it hit me and I had to slap myself in the forehead. There may be a third unrelated fault in the circuit to the oil pressure gauge. It could have been reading low, due to a poor connection somewhere in the circuit, or a bad sender, for example. When the supply voltage went wacky, whether due to an IVR fault or AC ripple, the needle moved a much smaller amount and so wasn't as noticeable as the other two.
I could absolutely have a bad oil pressure gauge or sensor, etc. That's also a possibility.
All these problems ...
OK just a few more comments.
After I checked the battery output I did my "turn on all the electrical stuff" test and the gauges went up super high. The truck doesn't start running rough while the electronics are on. Strangely enough it only appears to be running rough when I shut things off. As the needles fall, the thing starts running rough and then putters out and dies. It's really weird.
Based on your battery suggestion though I can very easily run the truck, turn everything on and measure that voltage and see if I have just been timing my "turn everything off" properly so the battery is dying just when I go to turn everything off.
I will try to do that tonight so I can report back in a timely manner. Still I probably won't be able to take the dash apart this week.
ok So I will: Run the truck and check the DC charging voltage. Turn all the crap on and see how much that charging voltage drops. If it doesn't drop I can try changing different heater settings / high beams / whatever to see if there is some place that causes a charging problem. If it still doesn't die / run rough then I can try shutting everything electrical off. So far this has been what kills it. I can then check and see what happens there.
Old Oct 5, 2015 | 08:13 PM
c2z4s9's Avatar
c2z4s9
Ok here are the results.
With the truck running at idle the charging voltage was 15.5 Volts (all measurements at the battery).
Turning on the lights increased the voltage to 16.5 V.
Turning on the heat (full blast) further increased to 17.5 V.
I left it running like this for a while and it didn't die. Shutting everything off dropped the voltage back to 15.5 and then the truck died. This time I was only able to get the truck to die this way once. All other attempts the truck stayed running without issue and the voltage simply dropped back down to 15.5 V.
Why is the voltage increasing as I increase electrical load? This seems backwards to me. Is the alternator regulator performing more poorly as current increases ... somehow?
Either way I'm pretty sure 17.5 is too high. Alternator regulator at fault here?
Old Oct 5, 2015 | 08:19 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Wow!
Yeah way too high.
It should be at most 14.65v
Your regulator is at fault for, or not sensing load properly.
Old Oct 5, 2015 | 08:28 PM
ctubutis's Avatar
ctubutis
Yeah, voltage regulator - look at the wiring to it, too...
I'm used to ~14.2V at idle.
kr98664's Avatar
kr98664
Originally Posted by ArdWrknTrk
Wow!
Yeah way too high.
Agreed! Sounds like you are on track to fix it now. In addition to the bad voltage regulator, your battery may be toast if charged that high for any length of time. If not a sealed battery, at minimum check the electrolyte level.
You mentioned the battery was old, so I have no problem spending your money to suggest simply replacing it as a precaution. I've seen many apparent "charging" problems exacerbated by a weak battery.
Chances are your gauges will now behave themselves, too. Keep us posted.
Old Oct 5, 2015 | 09:15 PM
c2z4s9's Avatar
c2z4s9
ok thank you gentlemen. I'll change the alternator and let you know.
Old Oct 5, 2015 | 09:33 PM
ctubutis's Avatar
ctubutis
Alternator? Does it have a built-in voltage regulator? If not, it's not the alternator that's the problem....
Old Oct 6, 2015 | 07:17 AM
c2z4s9's Avatar
c2z4s9
All of the alternators that I've seen always have a little rectifier/regulator module integrated into the back of it, so I was thinking it was a module in the alternator... I guess I have to remember this is a little older than most vehicles I'm familiar with. Now I"m looking at pictures of the alternator I think it might be somewhere else. Let me check further.
Old Oct 6, 2015 | 01:51 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If the alternator has separate wires connected to it look for some of them to connect to an external regulator (tin box)
If the alternator has two plugs it is a second generation alternator with internal regulator.
In this case you should definitely change the rectangular plug with the orange/black wires.
There is a Ford TSB on that.
Old Oct 6, 2015 | 03:23 PM
kr98664's Avatar
kr98664
The high voltage could also be caused by a sensing issue. All components may be fine, but due to a bad connection, the regulator thinks voltage is lower than it really is, and mistakenly adjusts the alternator output to compensate.
One common source of such an error is a bad ground at the alternator case. A quick and dirty check for this is to run a test jumper between the alternator case and the battery's negative terminal. If the readings now come down where they belong, fit a permanent jumper to ensure a good ground at the alternator case.
Old Oct 6, 2015 | 04:32 PM
c2z4s9's Avatar
c2z4s9
Just to keep you guys informed...
I actually have a couple of voltage regulators.
I have a F250 from the same year (85) and I found another regulator in my "stock".
trying both regulators produces absolutely no difference in charging voltage behavior (still wicked high).
I'm going to try kr98664's grounding idea.
After that I guess I'm chasing wires...
Old Oct 6, 2015 | 04:39 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
For some reason your regulator isn't sensing state of charge or system voltage.
The alternator is putting out all it can at whatever rpm's it's spinning.
This is going to boil your battery and warp the plates.
Check that the regulator itself is grounded (scrape some paint or rust, whatever) though I expect if you've swapped it it should be okay there.
Do you have an ammeter or idiot lights on your dash?
Old Oct 6, 2015 | 05:02 PM
  #28
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The yellow/white wire must 'tell' the regulator what the system voltage/state of charge is.
It would usually connect to the hot stud of the starter solenoid.
Dave Franklin offers a good explanation and diagrams here:
https://www.ford-trucks.com/forums/449569-1g-alternator-and-regulator-wiring.html
Old Oct 6, 2015 | 06:40 PM
  #29
c2z4s9's Avatar
c2z4s9
When I ground the body of the regulator the charging voltage drops to 14.5. Impedance measurement between battery negative and that fender (bolts that hold the regulator) is high. Alternator impedance to ground is 0 so that looks ok. So it looks like I got it. I have a bad ground to the passenger side fender.
It's dark now so I'll either find the ground cable and reconnect it or make one tomorrow.
Hopefully that fixes all my problems at once.
Old Oct 6, 2015 | 06:43 PM
  #30
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
That's really crazy.
The starter solenoid grounds through its mounting ears.
You shouldn't be able to get the truck to turn over if the fender has no ground.
