Porting?
Old Aug 3, 2003 | 10:33 PM
coops's Avatar
coops
Porting?
Ok, no question is a dumb question right? Ive been studying these threads for a while now and I'm really curious what it actually means to port your head? Thanks for you patience.
Old Aug 3, 2003 | 10:40 PM
steve83's Avatar
steve83
Porting?
It means you grind out some metal to increase the size of the intake & exhaust journals (ports) in the cylinder head to increase the flow (decrease pressure) thru them. You have to be VERY careful not to remove too much metal because you can weaken the head or cause hot spots if you don't know the thickness of the casting and how heat flows thru the metal.
You'll usually hear "porting & polishing" used together. Since the factory does as little machining as it can (to keep costs down), they leave the surfaces of the ports rough, just like they are after the sand casting process that forms them. It's common to smooth out these surfaces, especially after a porting job, to further reduce the friction against the air & exhaust flowing across them.
Old Aug 4, 2003 | 09:09 AM
coops's Avatar
coops
Porting?
Thanks for the explanation.
Old Aug 4, 2003 | 09:22 AM
paulfix's Avatar
paulfix
Porting?
You also match the ports where they join another component ie manifold against head, so the joint is smooth and does not interfere with gas flow, just as steve said above
