300 horse i6
Old Aug 3, 2003 | 09:52 PM
my79f's Avatar
my79f
300 horse i6
i would like some input on some parts to get 275 to 300 horsepower out of the i6. any input would be great. also if anybody has a sound bite of the thrush mufflers that would be great to hear
Old Aug 3, 2003 | 10:26 PM
warren b's Avatar
warren b
300 horse i6
If your going to shoot for numbers like that, you had better go for a stronger bottom end first. Your gonna' have to rev past 3600 rpm's to get 300 horse, and I've heard the first thing to fail from revs in these engines is usually the connecting rod bolts. So if it were me, that would be the first thing upgraded. After that I would work on flow; offenhouser intake, 4barrel carb, bigger cam, port work, and either headers or efi manifolds. There are some guys here with alot of experience working over these motors. They will probably give you alot more help than I can. good luck
Old Aug 3, 2003 | 10:50 PM
rhetor's Avatar
rhetor
300 horse i6
the guys at the fordsix.com forums are pros with this.
I would think you'd want lighter pistons if they're available.
Old Aug 3, 2003 | 11:39 PM
my79f's Avatar
my79f
300 horse i6
what about a clifford dual carb setup. is that overkill or would a single four barrell work just as well
Old Aug 3, 2003 | 11:51 PM
FordRacing2's Avatar
FordRacing2
300 horse i6
I believe two carbs would be too much for the inline six.
Old Aug 4, 2003 | 10:25 PM
wildjon300ci's Avatar
wildjon300ci
300 horse i6
About the only way your gonna hit 300hp that's driveable on the street is with boost. Also, the twin 2bbl carb is overkill without head work and a REALLY lumpy cam.
Old Aug 5, 2003 | 11:58 AM
Vampiro's Avatar
Vampiro
300 horse i6
.030 over to 303, 10:1 compression with a cam, headers high-pro everything and mabe you can get those numbers. itds easier to drop a 351C that already has 300 ponies in it into ur truck, or even a 302
