two part question
Old Sep 17, 2015 | 06:58 PM
Bigtom04's Avatar
Bigtom04
two part question
1. i looked all over in my dash to get the door code can not find it anywhere is there any other way to get it?
2. when i had my dash apart to change my radio. i found a plug between my 4x4 selector and defrost button. anyone know what that is for? the blue one
Old Sep 17, 2015 | 07:41 PM
7.3Excursion4x4's Avatar
7.3Excursion4x4
Someone told me it was the thermometer for the AC system
Old Sep 17, 2015 | 09:59 PM
Lance Helmert's Avatar
Lance Helmert
Look in the tech folder for how to get your door code.
Old Sep 18, 2015 | 12:11 PM
zapola6's Avatar
zapola6
The blue plug, I do believe is for the back up sensor on/off.
I pulled that specific switch plate out of an 03 Eddie in the junk yard that had back up sensors, when I pulled the plate off of my 00 Limited I to had the blue plug that fit the the switch for the back up senors switch that came from the 03 Eddie
Old Sep 18, 2015 | 12:18 PM
pirate4x4_camo's Avatar
pirate4x4_camo
I guess the back up sensor on/off as well
Old Sep 18, 2015 | 12:20 PM
Bigtom04's Avatar
Bigtom04
Hmmm. Then I'm gonna have to look and see if there is any wires behind the rear bumper for the sensors then
Old Sep 18, 2015 | 01:30 PM
mecdac's Avatar
mecdac
Ask a Dealer.
Old Sep 18, 2015 | 03:11 PM
A Rodder's Avatar
A Rodder
You cannot see it unless you use a small mirror attached to a stick about 14" long. The sticker has 5 numbers on it the you will view in a reverse order of how the will need to be put in.
There is that white batting that needs pushed aside and it is on the vicinity of the stereo up under the dash.
Old Sep 18, 2015 | 03:13 PM
zapola6's Avatar
zapola6
It works.... Easier when someone is reading numbers and you are pushing buttons...
https://www.ford-trucks.com/forums/1...l#post10496445
Old Sep 18, 2015 | 05:16 PM
2wdDezlX's Avatar
2wdDezlX
I was able to get mine by putting cell phone up there and taking a pic. It took about 3 times to get it postioned correctly, but it did work. And I think the other plug would be for backup sensors.
Old Sep 18, 2015 | 07:36 PM
Bigtom04's Avatar
Bigtom04
i keep looking and i cant find anything
Old Sep 18, 2015 | 07:38 PM
2005 Ex Limited's Avatar
2005 Ex Limited
Oh oh OH OH!!! I did this to get my door code. You need to stand on your head with the dash apart ('05) to get it, but it's in there.
Old Sep 18, 2015 | 08:07 PM
LivingLarge's Avatar
LivingLarge
Originally Posted by mecdac
Ask a Dealer.
This^^^^^^^^
Old Sep 18, 2015 | 09:28 PM
Greenscobie86's Avatar
Greenscobie86
I found mine this way:
Wasn't hard at all, just took a nice LED light to see it.
Old Sep 19, 2015 | 08:24 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
From the sound of things you have an XLT Excursion. That plug is indeed for the reverse sensing system.
