replace engine?
Plus my search has this "new toy" aspect but nothing I'm seeing (like minivans or an Expedition) is enough of a toy *with* function to get me to lose my van. Almost 30 years now that I've had a big van...the Ford is by far the best one I have ever owned and it's got more miles than any of the others did when I sold them. Honest, Ford does build some tough trucks and these vans are a doggone icon in America.
I have maintained that we would have no plumbers, carpenters, flooring people, electricians, utility workers, ambulance chassis, etc. without white Ford vans. Civilization as we know it would not exist without Econolines
Good luck,
George
Get a couple estimates; even let a shop diagnose, it may not be as bad as you thought.
At least you don't have a rust bucket (Midwest rust belt here!) John
But then they said it quit on them, and after messing with it, they decided it was the air fuel ratio sensor. They replaced that and say it runs fine. The oil is clean and they aren't getting any white smoke.
But I know what I saw, and I tried it several times. Does anyone think my symptoms can be explained by a bad sensor or are they missing something?
I'm having them do the 90,000 mile service and a tuneup and hope for the best.
When I gave up and got out of the seat, I tried it one more time and caught the sight of white smoke out of the corner of my eye. I assume it was steam -- it dissipated very quickly, and left no smell or smoke in the area.
A friend said to check the oil, but since I use a wheelchair, I can't get up high enough to even open the hood, let alone check the oil. But he said white smoke is head gasket for sure! Reading online, various auto advice sites said the same. This forum suggested it could just be the intake gasket.
IF there's nothing in the oil, and it's running now, I suppose this was all a false alarm. But steam implies some fluid in the engine, right? So I'm confused.
White smoke is usually gas. Black smoke is usually oil.
I wasn't there so it's hard to diagnose from here.
I have to assume the latest mech. looked at the usual things. Oil and water.
Was the puff of smoke/steam coming out of the exhaust pipe or from under the hood or thru the grille? Was the engine definitely cold at the time or did it run a short while or was it fully warm? Exhaust systems accumulate water vapor, and after a cold start, the exhaust may steam and/or spit water droplets for a while. This is normal; one of the by-products of combustion is water.
If the oil is clean, that tells me the head and intake gaskets are probably OK; the oil would be milky and sludgy if it had coolant mixed in it, and the coolant could likewise have oil in it and leave black gooky residue in the overflow bottle. Usually a head gasket failure would let the coolant and oil passages bleed into one another under pressure while the engine is running. You could also have the shop pressure-test the cooling system (they pump up the pressure thru the radiator cap and see if that pressure bleeds off indicating a leak somewhere).
If it runs good when you get it back, I would proceed to drive it with a fair amount of faith; one suggestion I would make is to arrange for maybe a full-service gas station or a friend to check your oil and your coolant every time you fill up with gas for a month or two. You are looking for milky looking oil with coolant in it, or signs of oil in the coolant (as well as a possible drop in coolant level). If the oil stays clean and full, and the coolant stays clean and full, all is well. If you do see steam rising out from under the hood, it *may* be a leaking gasket, but as an engine warms up, there is sometimes rain water on the radiator that steams off when the hot coolant hits the radiator, and maybe even some places on the engine that can get little puddles or rain water or AC condensate water on it and that can steam off.
I hope your immediate outcome is just a solid running van. These vans are tough and reliable and it is rare that a doomsday scenario happens.
Best of luck to you,
George
The steam was coming out of the tailpipe. If it had been a cold winter morning, it would have looked just like that, but it wasn't. It's been over 90 every day here for weeks, with no rain (central California in a drought!) I was trying the van around noon. I had tried to start it maybe four times when I saw the steam. I hadn't run it for a few days before that.
I'll keep an eye on it. I drive it so little that a tank of gas lasts me a month, but I will drop by this garage after I've run it for awhile and have them check it again. They seem pretty helpful.
If you can use this shop and develop a friendship and trust with them, that should be a great strategy for you; they will get to know you and your van, and should be able to take note of any changes in its health.
Again, best of luck to you,
George
(20 year old 4.9L I-6)
Facing a repair bill that would be worth more than I am, I punted. After doing some on-line research, I bought this stuff at Advance Auto Parts:
K & W Chemical FiberLock® Head Gasket & Block Repair, 32 oz.
<table class="table-prod-info-block" width="100%"> <tbody><tr class="topTD"><td colspan="3" class="topTD">
</td></tr> <tr> <td class="table-prod-info-block"> Part No. 401224-6 </td> <td class="warranty-prod-info-block">
</td> <td>
</td> </tr> <tr class="bottomTD"> <td colspan="3" class="bottomTD">
</td> </tr> </tbody></table> <table width="100%"> <tbody><tr> <td width="58%">
</td> <td width="38%">
</td> </tr> </tbody></table> $25.99, was $35.99, you save $10.00
The lower price is ONLY available if you order on-line!
This is the only head gasket fixing goop I found that does not require you to drain the engine; says on the bottle that it works with all coolants. I followed the directions to the letter 3 weeks ago and have put on a few hundred more miles. I haven't lost a drop of coolant since and the engine SEEMS to be healthier than before. I don't know how long this will last, so I'm crossing my fingers and my toes.
Not my style... For all I know though, the sealant will work for years. Good luck!
