New starter drive and now just a click?
One peculiar thing they have both done. When I turn the key and the engine starts to fire but I misjudge and let the key go too soon. The engine will fail to fully start and will get a low groan from the starter that could be teeth against teeth. I have asked about it before but after talking to Joe Smith at the Early Ford V8 Picnic he mentioned that I might be missing a bracket on the back side of the starter that hold up the tail end? I do not have this bracket but I don't have access to my diagrams to see what it looks like.
I found the part (maybe) on Macs site. The One place says it is for the 239 and another, under "Applications", says it is for the 226 only but presumably I should have had one of these all along.
Ford - Ford Starter To Oil Pan Bracket - Ford 239 Flathead V8 With Manual Or Overdrive Transmission | 51A-11140 - Macs Auto Parts
1A-11140-A (replaced 51A-11140 & 8A-11140-A) .. Bracket-Starter Motor to Oil Pan Bracket / Obsolete
Pic: Scroll down to 11140 / C = F1/F100 / D = F2/F250 / Y = F3/F350
I've had this happen a few times on my '52 since I've owned it. Mine has the bracket on it, too - but something isn't quite right, probably a "spot" on the back side of the ring gear somewhere. One thing you can do to "un-stick" it, is put the truck in high gear and rock it back and forth a bit. You'll hear a "clunk" and then it will be "fixed" until next time it happens. Mine can sometimes go years without doing it. - Bob
I am having a problem with mine all of a sudden.
Pulled it and looks ok during bench test, put it back in and it still just trys to turn but cant, can turn engine by hand so its not locked.
I jump direct to the starter and noticed a spark in a random place on the motor like a short.
Tested the starter down to ground ohms test and it failed that, do they go down to ground?
It is a 12v neg earth setup but original 6v starter which has been working fine until I gave it a decent run up the road and back.
on
John, I offer this as reference when you decide to rework your cables.. it's info I gathered when I wired my truck....it might give you some ideas...the first couple of pages is about the battery cables, the rest is general truck wiring I did
https://jniolon.classicpickup.com/wiring/wiring.htm
good luck
john
good luck
john
Just had a similar problem, bought a rebuilt starter From a national parts house and long story short it had a dead spot on the commutator and would work fine 9 out of 10 times until dead spot on the commutator would stop spinning right under a brush. At that point the starter would not work unless the armature was turned slightly and the dead spot was not sitting under a brush.
Driverjoe92
10-20-2019 06:17 PM
chrisb_93
01-27-2015 05:07 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
01-19-2015 12:28 PM
