is it possible to add factory ford efi onto an older motor??
If i pirated the intake, wiring and computer from a 460 efi Van
can i get it to work???
I know all about the hard lines and fuel pumps etc from my
5.0 mustang days...
Just wodering if i also took a speed density system from a mustang and used that instead too???
You can doit, but probably will be difficult to tune up if you use stock computer, also you can get a lot of fault codes. Could be better replace computer for any model you can reprogram to obtain all possible HP from engine.
There are more 460 Van's out there than anything else. Almost all of the smaller Motorhome's are on a E-350 chassis, and they all had 460's in them up until about 1998
