interior help
Old Sep 13, 2015 | 11:15 PM
greenf150flareside's Avatar
greenf150flareside
interior help
Can someone tell me what color my interior is supposed to be? The code is CR3.
Thanks
Old Sep 14, 2015 | 11:50 AM
WhatsAChevy?'s Avatar
WhatsAChevy?
Thanks
What year is the truck?
Here is a Google image swipe..Also check out the Sticky on requesting a build sheet.
Old Sep 14, 2015 | 01:10 PM
ctubutis's Avatar
ctubutis
Can't say I'm 100% positive at the moment, but I don't remember there being any 3-digit paint codes... post a picture of your certification label...
Old Sep 14, 2015 | 05:30 PM
greenf150flareside
"WhatsAChevy?"
Its a 1980 with the ranger trim....
"ctubutis" From what im told the 3 digits in the body section on the door jam is your interior color... Could this be wrong be wrong??
Old Sep 14, 2015 | 05:55 PM
WhatsAChevy?
My thoughts also Chris.....I was hoping for a 2 character code to cross reference to a five digit PPG.
Old Sep 14, 2015 | 06:04 PM
WhatsAChevy?
Thanks
What color is it now and what is making you ask the question? Do you think it was changed from factory? I'm thinking a little bit of backround info might be helpful in responding to your question. My best guess would be to follow the outline in the forum sticky for requesting a build sheet if you are looking to find out what your truck was assembly line built with.
Old Sep 14, 2015 | 06:24 PM
greenf150flareside
Old Sep 14, 2015 | 06:25 PM
WhatsAChevy?
"WhatsAChevy?"
Can you take a picture of the label and post it?
Old Sep 14, 2015 | 06:37 PM
ctubutis's Avatar
ctubutis
The BODY code *contains* the paint code... I see it's a MY 1980... maybe Bill will be kind enough to look this up in his books, I'm on a tiny laptop without that stuff....
Old Sep 14, 2015 | 06:41 PM
WhatsAChevy?
No paint codes on the tag
Your tag shows body manufacturer codes.....I don't see color codes. which should be on the top line.
I would consult NumberDummy about your tag. He is a Ford Service Parts Manager.
Old Sep 14, 2015 | 07:30 PM
ctubutis's Avatar
ctubutis
<p>I was wrong, the exterior paint code is contained (I think) in the TYPE-GVW field and not the BODY field.... that would contain the interior color...</p><p>Paging @NumberDummy</p>
Old Sep 15, 2015 | 08:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
^ Chris, it's not a good idea to volunteer information, especially when you are unsure. ^
7M is the exterior paint code: Dark Pine Metallic
Body code: The first two digits define the seat upholstery and the trim level(s), the 2nd digit also defines the interior paint color, the third digit defines the body style.
CR3: CR = Pine Cloth & Vinyl - Ranger or Ranger XLT / R = Medium Pine (1980) / C = Regular Cab with Flareside pickup box.
Type/GVW: F140 = F150 4WD Pickup .. 5,600 lbs. Gross Vehicle Weight Rating (1980).
Old Sep 15, 2015 | 08:37 AM
ctubutis's Avatar
ctubutis
<p>
<strong>^</strong> Chris, it's not a good idea to volunteer information, especially when you are unsure. <strong>^</strong>
</p><p>Yeah, I know... I'm just trying to help the guy, and I figure if I post to the thread, I should be able to more easily find his question again later when I have the books...</p><p>I was thinking of the interior trim color, I remembered it's someplace in that BODY (I think) code... the exterior color, I totally forgot about... it wasn't until I was on my way to work this morning when it occurred to me, it's ABOVE that lower line of codes and is labeled all by itself - which whatsachevy (Don?) had mentioned earlier...</p><p>I get myself caffeinated up and try to do 1,000 things all at the same time, none of them very well it seems....</p>
Old Sep 15, 2015 | 10:28 AM
NumberDummy
Originally Posted by ctubutis
I was thinking of the interior trim color, I remembered it's someplace in that BODY (I think ) code.
Sometimes, people type stuff before shifting their brains into gear.
I had forgotten that the paint color of the interior is the 2nd digit of the body code, but it's found in the paint section, not in the soft trim section.
So noted.
Old Sep 15, 2015 | 10:41 AM
1986F150six's Avatar
1986F150six
ctubutis and NumberDummy... both of you are an asset to the forum. Thanks from all of us [members]!
