Sponsored by: Real Truck
Ford navigation
Old Sep 12, 2015 | 11:38 AM
willtim1234's Avatar
willtim1234
Ford navigation
I have a 2013 F350 4x4 Lariat CC with Ford factory Synch/navigation. for no apparent reason, my gps/map shows me a hundred yards off coarse, and at times, it appears "lost". I has worked perfectly for 63,000 miles. I did recently have it serviced at the dealership and I bought new tires that are larger.Any ideas? Thanks.
Old Sep 12, 2015 | 11:48 AM
seville009's Avatar
seville009
See if rebooting it helps.
https://owner.ford.com/how-tos/sync-technology/sync/software-updates/how-to-perform-a-master-reset.html
Old Sep 12, 2015 | 12:22 PM
FordIVTteam's Avatar
FordIVTteam
Official Ford Rep
Hi willtim1234,
This is a common issue that occurs after modifying the tire size. I recommend contacting your dealer to find out if the available GPS update can resolve this for you.
Let me know how it goes.
Whitney
Old Sep 12, 2015 | 03:06 PM
willtim1234
Thanks. I went from a 275 tire to a 295 tire. About a 1-1.5 inch difference.
Old Sep 12, 2015 | 10:14 PM
Lees350's Avatar
Lees350
From what I understand, tire size shouldn't make a difference in the actual position of the vehicle. As it is pulling data from the satellite to the receiver in the truck to locate the gps position. I think the only difference that tire size would make is the time and miles calculation to your destination.
It does seem weird that it happened after the tire swap, so maybe the newer systems use vehicle dash (speed and distance) to assist in vehicle position? Perhaps there's something wrong with the transceiver, or its not picking up enough satellites to "triangulate" the position correctly.
Old Sep 13, 2015 | 08:12 AM
sammy77's Avatar
sammy77
There's probably nothing wrong with the gps components. This is a common issue after changing tire size. Most times, the reboot is all that's needed.
Old Sep 13, 2015 | 09:32 AM
willtim1234
Thanks, everybody. I will reboot and let you know.
Old Sep 13, 2015 | 12:02 PM
willtim1234
The master reboot made no difference. I am at a loss. I don't understand how changing tire size could make a difference. I can take a $100.00 Garmin unit, put it in any vehicle, and it will show me exactly where I am.
Old Sep 13, 2015 | 12:21 PM
sky Cowboy's Avatar
sky Cowboy
A GPS gathers signals from satellites in space and tells you where you are on the earth from triangulation of those signals.
Tire size should have no effect at all on the location being off.
We use gps in all the helicopters and they are accurate to within less than 3 feet always, unless a bad storm is in the area.
Sometimes a bad storm throws the signal off.
I can land in the exact same spot after flying around for hours and hundreds of miles. If i land exactly back on the marks in the grass from where i left and had that spot saved in the gps. It will usually have no more error than showing 1 foot difference. Although I have seen it show as much as 3 feet at times. But 100 yards is ridiculous.
Old Sep 13, 2015 | 12:26 PM
sky Cowboy's Avatar
sky Cowboy
Maybe see if something is blocking the antennas signal in some way.
Poor signal is the only reason i have seen any of my gps units far off.
Even my old and very cheap garmin etrex handheld.
Its dirt cheap, and on a bad day could be off as much as 7 or 8 feet.
Old Sep 13, 2015 | 12:32 PM
seville009's Avatar
seville009
Try what this guy did, which he said worked.
https://www.ford-trucks.com/forums/1292379-taller-tires-messing-up-sync-gps-n-speedometer.html
Old Sep 13, 2015 | 01:42 PM
willtim1234
Thanks, Seville. I will try the 20 minute disconnect and let you know.
Old Sep 13, 2015 | 03:37 PM
willtim1234
Seville, you are the man. Disconnected my battery for 20 minutes and drove 35 miles on the interstate. GPS/map are back spot on. I will keep you posted. Thanks a million!
RainDesert
Jan 5, 2017 06:15 AM
jim0517
Dec 30, 2004 10:17 AM
98Cobra
Dec 18, 2004 02:38 PM
Chaps
2004 - 2008 F150
Feb 7, 2004 12:58 PM
Walter Barrett
Jul 20, 2000 09:14 PM
