Aerostar Ford Aerostar
Bulb or Fuse?
Old Aug 3, 2003 | 01:23 AM
Jakea's Avatar
Jakea
Cool Bulb or Fuse?
2 questions. Is there a bulb or a fuse for the floor board stick panel (Park, Reverse, Neutral, Drive, 1, 2) cannot see the letters at night. Also the lights on the radio are out, cannot see the stations or time? 90 4.0L
thanks for your help!
Old Aug 3, 2003 | 07:12 AM
HomerWinzlow's Avatar
HomerWinzlow
Bulb or Fuse?
There are replacement bulbs you can get for both. The indicator bulb for the shifter is under the cover and the radio you pull out, remove the top cover and replace the bulb. On late models you have to replace the whole radio, so you are fortunate.
Old Aug 4, 2003 | 02:38 PM
Jakea's Avatar
Jakea
Bulb or Fuse?
Thanks, but how do you get under the shifter cover? DOes it pop out or are there tabs?
Old Aug 4, 2003 | 03:39 PM
aerocolorado's Avatar
aerocolorado
Bulb or Fuse?
Floor shifter cover just pulls off. Radio bulb is a dealer item. None of the major parts stores carried it.
Old Aug 6, 2003 | 10:03 AM
Jakea's Avatar
Jakea
Bulb or Fuse?
I can't budge the four screws that hold the radio in. I even broke a screwdriver on one of them. I sprayed them with wd 40 and one screw finally came loose, but I the other three I couldn't loosen.
regarding the cover for the shifter, it looks like two parts a trim part and the part that is attached to the shifter that has the letters on it. Do i pop off the trim part first? and then the other part or what?
Thanks!
Old Aug 6, 2003 | 10:18 AM
johncfox's Avatar
johncfox
Bulb or Fuse?
I got the bulb for the radio at Wal-Mart.
NashvegasMatt
Aug 26, 2016 09:41 AM
tedsfi
2004 - 2008 F150
Jun 20, 2014 05:49 PM
1981fordstepside
15
May 14, 2014 05:21 AM
Talyn
Oct 27, 2009 04:10 PM
billy12360
27
Sep 9, 2008 11:07 AM
