My truck has everything extra in it except air. Can I put in A/C if I dont have factory air vents. All I have is defrost and heat I have fresh air type vents at my feet. I do know they make add on air kits for trucks without factory air all I want to know is where can I get the parts how hard is it to do and is it worth it
There are several active threads in this forum.
If not page ONE here, they will be on page TWO.
In Fact there is an A/C thread JUST 2 threads down from this one.
Maybe have a look ?
You can get underdash A/C
or the more expense $$$ +T ime Consuming alternative.
There is more to it than changing the dash & impossible with the controls you have
I have a 78 f-150 and i am about to put a/c in it and with the vents what i did is went to a junk yard and pulledthe dash (with the vents) and the controls with a/c.
see if that helps
