6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
CAB OFF Suggested Maintenance
Old Sep 10, 2015 | 02:52 PM
TRILLS's Avatar
TRILLS
Hello FTE! Haven’t posted on this site before, I’m usually on PSD.org but my job started blocking that site so I’m here too! I have the dreaded p0088 going on and I know I will ending up getting a replacement HPFP with the CAB OFF procedure. My question is can you give me a list of good preventative maintenance or even MODS, that should get done while the cab isoff? Background on the truck is I bought it about 4 months ago with 148K on it.It still had the DPF and EGR’s intact and running at time of purchase. I deleted the DPF and CAT and did the software EGR delete with the Spartan 210 tune. Since this truck hadthe DPF and EGR intact up till almost 150k miles on the OD, I’m thinking there should be some other things to take account for possible preventative replacement maintenance. I’m looking for longevity, not crazy power gains. The Spartan 210 and2 10tow tunes give me all the power I need.
Maintenance Items:
- HPFP /w harness
o Possible fuel system overhaul if metal shaving are found in the secondary fuel filter
- Fuel Pressure sensor
- Fuel Filters
- Oil Cooler
- Rocker Arms
- Body Mount Bushings
- Thermostats
Mods:
- PCV reroute (I can to later)
- Coolant bypass filter (I can do later)
- EGR delete (I have to do this myself since Calishops will not delete emission system components.)
Please let me know if I'm missing anything in my list above. I appreciate all recommendations and ask that if you do recommend something please let me know if there is a product better than OEM that you suggest going with.
Old Sep 10, 2015 | 03:47 PM
UGA33's Avatar
UGA33
Good list with the rockers. I would replace the exhaust manifolds with 6.0 manifolds and custom uppipes. Uppipes like to blow at the worst time.
Old Sep 10, 2015 | 03:52 PM
UGA33's Avatar
UGA33
Forgot to ask. What is the budget?
Old Sep 10, 2015 | 04:05 PM
TRILLS's Avatar
TRILLS
Hey UGA33! thanks for the 6.0 manifold recommendation. I have herd this being done on other 6.4 forums. I wonder how much a conversion like that would cost. Budget... well right now with the items I listed under Maintenance items (minus the fuel system overhaul) is about 6k, since it will be done at my local mechanics shop. But if something else sounds like it should be added then I might add another 2kish (again this is possible as long as I don't have to do a full fuel system over haul which I know will take me closer to 9k with Cali Tax added). It's All about doing it right the first time and while everything is easily accessible. Maybe Studding the Heads should be added but again not sure how much that would cost (head gaskets, etc...)
Cheers...
Old Sep 10, 2015 | 04:45 PM
UGA33's Avatar
UGA33
I was gonna mention doing the studs, but I understand if the fuel system is toast that bill will drive it up big time. If money wasn't an issue, I would say stud it. As for the uppipes, custom uppipes with 6.0 manifolds run anywhere from $600-1k. Depends on where you get em. I think your list is good. Especially the oil cooler. If I were to recommend a performance upgrade, it would be a 71 or 72mm atmospheric charger upgrade. They are a really good "bang for your buck" mod.
Old Sep 10, 2015 | 08:15 PM
dlibson's Avatar
dlibson
I would also do new push rods, and consider doing studs. Even if you do one at a time, and leave the rest alone it's a good upgrade and future selling point. Radiator hoses if they aren't already upgraded. I would also recommend pulling the water pump and checking for any cavitation issues on the front cover.
TJ8
Jul 16, 2019 04:41 AM
bluemtn95ford
Jul 12, 2016 09:47 PM
speakerfritz
Dec 4, 2015 12:31 AM
Built_Ford_Tough_757
Apr 11, 2010 10:31 PM
northerndave
Mar 9, 2009 10:00 AM
