351m/400 mild build
Turning 6800 rpm with stock pistons and rods?
Those stock heads won't make power at those engine speeds even with a 3.5" crank.
Sounds to me like there's some confusion, at least I'm confused.
R.
Once I pull my heads off I will measure the stroke. Pulling isn't about power per say, more about wheel speed. Faster I spin the tires, longer I go before the sled stops me.
Like I said I want to go with a roller cam and some mild porting while still running pump gas. So I want to know which roller cam to go with. And what else to do to the heads.
I have a street mod truck with a 460. Stock crank, rods, pistons and a cheapo roller cam. Runs c12. I did tons of porting to those heads. They are not scj heads. Stock 460 heads. I can fit a golf ball inside of the exhaust ports. But its street mod. I want to build my 400 up a bit for stock class.
If you have and are going to stick with a 351M, save your money. It is a low compression engine, which will limit your choice of cams to short duration, high lift jobs. No 6800 RPM power with those afaik, I think they are listed as 4500 or 5500 RPM limit.
If you have a 400:
--porting would be a rough finish on the intake, smooth on the exhaust. You can probably google a port and polish video.
--whoever you buy a cam from will tell you all about it and what you need. Roller = $$. Since the roller set up is all different, you will be buying pushrods, springs etc.
--if your heads need work like valve guides, consider aftermarket heads
--look on the TMI site for the piston you need to get into the 9s compression wise.
--look at the builds on the TMI site and pick and choose from that formula as your budget allows.
Again, forget any notion of making real power out of a 351M. Donate your cash to a worthy cause instead.
If you have a 400:
My compression ratio is in the 9's my heads were plained before. Cam that's in it is flat tappet but not stock. Crank, rods and pistons are stock besides a previous .010 turn on the crank.
Once I get the crank back and heads off I will check the stroke. As far as porting the shop will be doing it for me, I don't want to run higher than 93 octane. I'm not looking for a 800hp motor. I have my 460 for that. I just want some more get up and go without stroking the 351m/400. Can't run aluminum heads in stock class. That's why I'm working these heads. I will check tmi site.
If they have the water jacket all the way around then you really do need to port them. Just rounding off the plateau around the exhaust valve helps a lot. Ported the exhaust they can be made better than a stock BBC exhaust. I'm sure if you really ported the whole head 500+ HP is possible. Stock valve sizes are just fine. Porting yourself will save a bunch of money.
As far as other modifications, rocker arm studs would be nice, but costly on a canted valve head because each pedestal is canted. I, and many others are using Scorpion bolt on roller rockers. Their customer service is fantastic.
Get the Keith Black hypereutectic pistons from Tim Meyer, he's great... Just swamped right now I'm sure. He's got a Project going for NEW 351C based race blocks going.
I would polish the rods and get ARP bolts installed. I'm using the smallest Howards hydraulic roller cam, but don't have enough time to know if I could recommend it or maybe the next larger one for your application. If you run a roller cam - use hardened pushrods for sure. They are really long in the tall deck of the 351M/400.
The Keith Black pistons work for the 400, will not work in a 351M.
How did you figure 9:1 just based on cutting the heads? That's almost a full point.
351M/400 Performance Build Up
Rod is the same for both motors at 6.58".
Piston compression height on the 351M is listed at 1.947" or 1.921" --other variations probably exist depending on the piston supplier. The smaller that number, the lower the compression and poorer performance will be, as that will mean the piston is further down the hole.
Piston compression height on the 400 is 1.65", close to the same as the 351C. More info here, although I think some of the pistons he mentions for the 351M are no longer available based on other posts here:
M-Block 351M/400 Performance
Stroke for the 400 is 4", thus the crank arm is 2".
Stroke for the 351M is 3.50", so the crank arm is 1.75".
I will call the speed shop to see which crank it is
New build currently: .030 rods, .020 mains. Weiand plus non egr 4bbl intake, Holley 750 4bbl vacuum secondaries, 1 inch carb spacer, long tube headers, exhaust ports ported, gasket matched and polished, intake ports ported, new valves with 3 angle valve job, fuel pump delete plate, new oil pump and rod.
Still might do a roller cam 2,000-6,500 rpm. Not sure yet. Alot for a cam kit when I have a 460 sitting on my garage floor.
When I'm done porting heads with everything else I will be near 350-400 hp easily. On pump gas. Will put 1,000 to 2,000 miles on motor then test is at truck pulls. She's either going to pull hard or she's going to blow. We will see.
I'd suggest you make sure you have 9.5:1 or better compression, upgrade to ARP rod bolts and THEN a roller cam. Something like the Howards P/N 230245-10 - 225/229 degrees duration at 0.050" lift, and .576"/.600" lift, this should put you over 400HP if you've got even a moderate port job on the heads. I say Howards only because I've got their catalog in front of me, any cam company can set you up with something similar. You'll need a properly prepped rod for sure.
Like a lot of people here I'd say it would be worth the effort on a 400, but probably not on a 351M. Your call on that one, if you want to do the 351M just to see what it can do - I can respect that!
One question I do have. My 460s dissy I had to install a bronze or brass gear because I was shearing the stock one up. Should I do this on this motor or is the stock safe for 400hp?
As far as the cam I'm not sure what I'm doing yet. I want to keep this under 3grand. I have 450$ invested into my crank, bearings and gasket set so far. Still have to order my weiand intake and headers. That will be around 500$ or so. 300$ or so for all the arp bolts. Hardened push rods(dont have a price yet) Then pay the speed shop to do a 3 angle valve job. When I'm done doing this much I will decide if I'm doing a roller cam or not as the speed shop will need to setup my heads for it.
I have a set of stock 2V cylinder heads that I gasket matched intake and exhaust and port polished every exhaust runner, removed the stupid EGR humps and matched the valve seat to bowl, smoothed and cleaned up all transitions and slightly cleaned up the chambers, I didn't want to remove too much and drop compression a lot they measured 78cc I am building a 500hp 400 and wanted to use these heads for a "stock" looking street thumper but, there is one crack in the #8 exhaust just under the exhaust valve seat and goes just between intake and exhaust seat. If you want to have stock heads, fix these and they will work well for you, all other things are within spec so you can just throw in good valves and springs etc. and these will flow good for you. Let me know
