460 Spark Plugs
Old Sep 7, 2015 | 05:00 PM
Amish Ford's Avatar
Amish Ford
460 Spark Plugs
Ok, when I installed this motor last year, I just got new plugs like the ones that were in there - Autolite 45..... Saturday, my wife went to the parts store, and they gave her Autolite 25's.
Which one is it SUPPOSED to take? This is a 1979 (ish) 460 in a 1986 F-350.
I'm thinking the 25's are correct......what is the difference between the two?
NATURALLY, when I go to change them, the parts store is CLOSED
Old Sep 7, 2015 | 06:01 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
25's are the right number for DSII ignition and .044" gap
I have had quality control problems with Autolite's and recently switched over to NGK UR4's.
These are their regular copper V-power plugs
Old Sep 8, 2015 | 01:06 PM
Amish Ford's Avatar
Amish Ford
Ok.....I guess I DIDN'T replace them last year! I went to install the 25's and they WILL NOT WORK! The 45's are a large plug (13/16 socket) and the 25's are a small plug (5/8"). They are also smaller diameter across the threads. I guess now I know for sure what to use, even though parts houses tell me different!
Old Sep 8, 2015 | 02:18 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
What kind of heads are on your truck????
Sure 25's are a "peanut" plug.
That's what the application calls for and the only thing I've ever seen in a D3VE (1973-1987) head.
Old Sep 8, 2015 | 08:54 PM
Amish Ford's Avatar
Amish Ford
I am now GUESSING that this motor is actually a 429 out of a Ford car........I will have to see if I can find some numbers on it.
Old Sep 9, 2015 | 04:07 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If that's the case and the engine has been swapped the only way to tell is to pull the pan and look at the numbers stamped in the crankshaft.
U vs Y.
This will tell you what the stroke is, EVERYTHING else is the same between 429 & 460's.
What are the head casting numbers?
D0OR, D0VE, or maybe the D1VE?
Old Sep 9, 2015 | 04:16 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Just now for $#!*$ and giggles I went to Autolite's site and looked up a '73 Tbird with a 429.
...calls for the same #25 peanut plug.
It's REALLY strange what you've got going on
Old Sep 9, 2015 | 06:56 AM
Amish Ford's Avatar
Amish Ford
BUT.....in 1971, that same T-bird 429 takes 45's......
Old Sep 9, 2015 | 06:58 AM
Amish Ford's Avatar
Amish Ford
U vs Y.
Well, it's in an 86, so the motor has to be pulled loose to drop the pan....so....that ain't happening! I will see if I can figure out what heads I have. They guy who had the engine before MIGHT know what he got it out of....
Old Sep 9, 2015 | 07:00 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Ahhh, The super craptastic low compression open chamber D1VE heads....
Eight years before the 1979 engine you suggested it was.
Old Sep 9, 2015 | 07:04 AM
Amish Ford's Avatar
Amish Ford
All I know is - it canme out of a 1979, I have NO idea where it lived before that. I was TOLD it was a 460 - and it still MIGHT be.....
Old Sep 9, 2015 | 07:13 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It could be 429 or 460.
The only difference is the crank throw.
Look for a number cast between the 2&3 head bolts on the outside.
429 ' s were never installed in trucks and not made in 1979.
Old Sep 9, 2015 | 07:43 AM
Amish Ford's Avatar
Amish Ford
I know.....that's why I originally thought it was a 460.....
Old Sep 9, 2015 | 09:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
As original 1968/79:
1968/72 429 = BF42 or BRF-42 / 1973 429 = ASF-42
1968/72 460 = BF-42 or BRF-42 / 1973/76 460 = ARF-42 / 1977/79 460 = ASF-42
429: 1968/71 Thunderbird / 1968/73 Ford/Merc Passenger Cars.
460: 1968/78 Lincoln/Continental Marks / 1972/76 Thunderbird / 1973/76 F100 / 1973/78 Ford/Merc Passenger Cars / 1973/79 F250/350 / 1975/79 F150 / 1975/97 E250/350 / 1983/97 F250/350.
Old Sep 9, 2015 | 12:30 PM
unofornaio's Avatar
unofornaio
Just took this of my 86 F350 1 TON 460
.43-.46 for the ASF 42 plugsIm assuming the 25's = 42's? ArdWrknTrk stated .44 for the 25's is this a standard (proven) number that works well for these? or just a good number in that range that is acceptable?
Thanks
