Bendix Pitman Arm vs. Ford/Saginaw
Old Sep 5, 2015 | 06:59 PM
FordStolz68's Avatar
FordStolz68
Would anyone know the actual physical differnce between C7TA-3590-L Bendix & C9TA-3590-E Ford/Saginaw pitman arms?
Old Sep 5, 2015 | 09:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C7TZ-3590-F .. Pitman Arm-Use with Bendix P/S / Marked: C7TA-3590-L / Obsolete
1967/68 F100/250 2WD / 1969 F100/250 2WD before serial number D96,001.
C9TZ-3590-C .. Pitman Arm-Use with Ford/Saginaw P/S / Marked: C9TA-3590-E / Obsolete
1969 F100/250 2WD from serial number D96,001 / 1970 F100/250 2WD / 1971 F100/250 2WD before serial number M00,001.
D2TZ-3590-B .. Pitman Arm-Use with Ford/Saginaw P/S / Marked: D2TA-3590-BA / Obsolete
1971 F100/250 2WD from serial number M00,001 / 1972 F100/250 2WD / 1973/79 F100 2WD / 1973/79 F250 2WD Regular & Super Cab under 8,100 lbs. GVWR / 1975/79 F150 2WD
xgkrx
May 5, 2017 05:34 PM
66with352
Jun 18, 2016 09:43 PM
shermy452
Oct 1, 2015 02:15 PM
lizardman1
Aug 15, 2013 06:50 AM
THAT.GUY
Apr 10, 2012 04:39 AM
