1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Mystery Engine Stalling
Old 09-05-2015, 01:31 PM
idlecarrots's Avatar
idlecarrots
idlecarrots is offline
Trailering
My 2002 7.3 will go dead when driving then not start up until after it has sat for a good hour. Then only run for about 10 minutes before dying again. The truck will stay running if left in park idling. It only stalls when it is driving.
I replaced the Camshaft Position Sensor and Alternator with Genuine Motorcraft parts. My next assumption is the ICP Sensor? Maybe.
I do have a kill switch on the truck that I thought might be loose--but I'm not sure. Any ideas?
Old 09-05-2015, 03:10 PM
madscientist's Avatar
madscientist
madscientist is offline
Have you tested to determine whether you are missing spark or fuel? That is where I would start. That first test is critical to determining what's wrong with the truck.
Old 09-06-2015, 01:34 PM
idlecarrots
Trailering
The 7.3 powerstroke does not have spark plugs. Checking the fuel is why I'm asking about the ICP Sensor.
Old 09-06-2015, 05:18 PM
ligito's Avatar
ligito
ligito is offline
First, bypass the kill switch and see if it is the problem.
Old 12-02-2020, 10:29 AM
Jacques Leveille's Avatar
Jacques Leveille
Jacques Leveille is offline
My Ford -350 had the same problem cut off while driving drove my insane until my friend put a test a
Old 12-02-2020, 10:06 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Originally Posted by Jacques Leveille
‘’Welcome to the Forum. This is a 5 year old thread...
ed dixon
Modular V10 (6.8l)
04-30-2016 03:56 PM
rlester
Escape & Escape Hybrid
03-07-2015 10:34 PM
Moore558
3.8 & 4.2L V6
03-29-2012 09:44 PM
shotgun
Electrical Systems/Wiring
01-01-2009 09:08 AM
dirtybroncoii
Bronco II
51
03-26-2007 09:45 PM
Quick Reply: Mystery Engine Stalling
