Speedo
Old Aug 2, 2003 | 07:29 PM
bigreave's Avatar
bigreave
Speedo
My rear end went haywire last week swaped in a new rear end I went from 247 gears to 308's now my sppedometer says Iam going 85 when i think iam going about 55. is this because of gears or what anyone know
Old Aug 2, 2003 | 07:55 PM
RRMike's Avatar
RRMike
Speedo
Without knowing what kind of rig you're talking about I'd say probably yes. Does the rig have a speed sensor on the rear or in the trannie/t-case?
Old Aug 3, 2003 | 12:29 AM
bigreave's Avatar
bigreave
Speedo
Nope no speed sensor just the cable to speedo. the truck is a 85 f150 strait six toploader 4 speed. I think it's jumping about 20 miles per hour. While going down the highway it said I was going 85 and a little old lady passed me when she did i saw 65 miles per hour
Old Aug 3, 2003 | 01:22 PM
RRMike's Avatar
RRMike
Speedo
Yeah if it's got the cable then the gear change will cause it to be off.
Old Aug 3, 2003 | 04:13 PM
Torque1st's Avatar
Torque1st
Posting Legend
Speedo
Sounds like a bad speedo cable along with the gear change. You should not be that far off with a simple diff gear change.
Old Aug 3, 2003 | 05:37 PM
bigreave's Avatar
bigreave
Speedo
now i am just following the flow of traffic, is there anyway to adjust the speedo?or should i just watch the tach ? The speedo worked fine until the switch.
Old Aug 3, 2003 | 06:22 PM
rclarke's Avatar
rclarke
Speedo
The driven gear on the transmission end of the speedo cable is easily changeable. To slow down the speedo you will need a gear with more teeth.
Old Aug 4, 2003 | 12:49 AM
bigreave's Avatar
bigreave
Speedo
where would i find just the next size up gear, junkyard?
Old Aug 4, 2003 | 05:29 PM
rclarke's Avatar
rclarke
Speedo
Easiest is a Ford dealer. I don't know if parts houses have them. When I was working in a dealership our rule of thumb was 1 tooth = 5mph thats pretty close. Take yours out count the teeth and note which way the teeth angle. There are right and left hand teeth.
Old Aug 4, 2003 | 07:37 PM
bigreave's Avatar
bigreave
Speedo
Ok I will hit varsity ford latter thanks.
