Factory Tach
Old Aug 31, 2015 | 06:07 PM
dnkensinger's Avatar
dnkensinger
Factory Tach
Just scored a gauge cluster with tach!! Super excited but I want to know if the wiring is already there for it in the instrument cluster wiring. I know the printed circuit has to be changed out, I have an NOS one for tach. I guess I just want to know if the wires are already in the connector so if I install the new printed circuit and tachometer, will it all work?
Old Aug 31, 2015 | 08:02 PM
FordPUMan's Avatar
FordPUMan
If you already had gauges in your original cluster then the new one should be plug and play.
Old Aug 31, 2015 | 08:13 PM
Franklin2's Avatar
Franklin2
Here's a link from the stickies at the top of the forum.
https://www.ford-trucks.com/forums/9...-question.html
Old Aug 31, 2015 | 08:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Your "About Me" profile says 1984 F250.
Be aware that 1980 uses a different printed circuit board with tachometer than 1981/86.
E1TZ-10K843-B .. Printed Circuit Board-Use with Tachometer, Amp & Oil Pressure Guages / Marked: E1TF-10C956-BA / Available from Ford
Applications: 1981/86 F100/350 & Bronco.
Rogue_Wulff
159
Nov 20, 2017 07:32 PM
Handegard
Feb 22, 2014 11:27 AM
xjpilot
Mar 20, 2012 05:28 PM
masseysbronco
Oct 24, 2010 12:06 PM
bishopgeer
Electrical Systems/Wiring
Apr 14, 2009 09:22 AM
