67 Ford
Old Aug 30, 2015 | 06:37 PM
Kurt1967's Avatar
Kurt1967
67 Ford
I have a 67 F100, currently it has a 240 in her. I'm looking to swap to a 302. I had a 68 years ago and did the swap using the 240 motor mounts but it wasn't right. Any suggestions on motor mounts. Haven't had luck finding them for a 67
Old Aug 30, 2015 | 07:33 PM
anthony myrick's Avatar
anthony myrick
https://www.ford-trucks.com/forums/3...gine-swap.html
Old Aug 30, 2015 | 07:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
SAME engine supports aka towers/stands/perches:
1969/79 F100 302 (no 302 before 1969) / 1975/79 F150 302 (no F150 prior to 1975) / 1977/79 F100/350 351M/400 2WD (no 351M/400 prior to 1977).
Old Aug 30, 2015 | 08:22 PM
67 StylesLide's Avatar
67 StylesLide
Originally Posted by anthony myrick
So unless I'm missing something here,,, this all says that for a 302 in a '67,, the frame must be drilled or custom mounts fabricated.
Good to know.
There are quite a few things that are "67 only".
Good question Kurt1967
Old Aug 30, 2015 | 10:22 PM
NumberDummy
Use the engine supports that I listed in post 3.
Old Aug 31, 2015 | 12:59 AM
RichS2659's Avatar
RichS2659
Good to know.
The frame will have to be drilled any way for the 302/351M/400 perches. It is just like a swap from a 240/300 to an FE. As a Big 6 uses the same perches as an FE, you just slide them to the next hole. So just use the 302 perches as ND said, line up the motor, and drill new holes and bolt in. Done.
Old Aug 31, 2015 | 04:59 AM
Kurt1967's Avatar
Kurt1967
Thanks for the info
Lowdwn
Jun 9, 2018 05:30 PM
Dano61
Mar 9, 2018 08:19 PM
veedogtoo
Sep 29, 2012 08:18 AM
finneys98xj
Sep 29, 2010 05:52 PM
vol1966
May 16, 2010 11:40 AM
