FE pushrods
Old Aug 30, 2015 | 05:38 PM
tbm3fan's Avatar
tbm3fan
FE pushrods
As if the intake wasn't a problem as I was tearing down I decided to measure the pushrods for the hell of it. First one was at 9.539 and I went really. So on one side of original to the engine when I got it I got two at 9.539, three at 9.571-73 and three at 9.560-65. Like where did a 9.539 come from? Same for the 9.571?
I guess I will take out my pushrod checker, make that buy one, since mine max out at 8.50" for small blocks.
Old Aug 30, 2015 | 10:28 PM
tbm3fan's Avatar
tbm3fan
Checked the other side and found two @ 9.535". Where do those come from? However, of the 16 total I did find one @ 9.62" stock length. At least the valve stem tips are all level across the heads.
Old Aug 31, 2015 | 09:12 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
<p>There are over and under-sized pushrods for these motors, as there is no adjustment at the rockers.</p><p>On the other hand, if the valves are all level, they really should all take the same length pushrod.</p><p>You're going to have to check valve-lash when you get the intake back on it (or it can be done with the intake off), and you'll need to keep track of which pushrod goes where. Using pushrods that are too long will get you bent pushrods <img alt="Evil Grin" src="https://www.ford-trucks.com/forums/images/smilies2/evilgrin0007.gif" style="height:19px; width:21px" title="Evil Grin" /></p>
Old Aug 31, 2015 | 05:12 PM
tbm3fan's Avatar
tbm3fan
I'll be checking every one of them. I did notice, the few times I could run at idle, that there was a lot of valve ticking not present before the engine was pulled and rebuilt.
Kyle Wood
18
Mar 22, 2018 06:40 PM
lannondiesel
Oct 14, 2014 06:12 PM
wyckedcombo17
Jul 6, 2013 10:00 PM
mmuenchow
Nov 7, 2010 06:03 PM
Six Niner
May 11, 2006 06:33 AM
