Which is better
Old Aug 29, 2015 | 04:39 PM
mtntop1's Avatar
mtntop1
Which is better
My question is,I have a 95 f150 302 with stock heads and stock rear end with 3.55 gears.I tow a 4500lb trailer and on level ground no problem.When I tow up hills and higher elevation ( 3000 to 8000 feet ) I struggle a bit.I changed the cam to a .480lift 260 duration,installed shorty headers and 3" cat back exhaust this help a lot but I need more.What would get me more towing power.Fords aluminum racing heads with 194 intake or switching to 3.73 or 3.90 rear end gears.
Old Aug 29, 2015 | 04:41 PM
easyridin's Avatar
easyridin
gears 100%. 3.73 4.10s anything lower that the 3.55s and you will feel a bigger difference before anything under the hood
Old Aug 29, 2015 | 07:49 PM
DeereFord300's Avatar
DeereFord300
4.10s would be a good jump with the OD. The 302 will feel much peppier on the lower end
Old Aug 29, 2015 | 10:59 PM
Encho's Avatar
Encho
The Southernmost Mod
Gears definitely, you'll also spend a lot less on them than more engine mods. You have done the Sixlitre tune-up, right? it's a very cheap way to gain some extra performance.
Old Aug 30, 2015 | 09:42 AM
mtntop1's Avatar
mtntop1
Will 3.90's give me that extra ommph from about 1000 to 3000rpm over 3.55's.I don't want to go to high.
Old Aug 30, 2015 | 03:15 PM
rla2005's Avatar
rla2005
What size tires are you running?
Old Aug 30, 2015 | 03:57 PM
mtntop1's Avatar
mtntop1
235/75/15 with a tire height of 28"
Old Aug 30, 2015 | 04:16 PM
'89F2urd's Avatar
'89F2urd
if it were mine, I'd be doing the heads. you stand to gain way more with the heads...and you could bump compression into the 10's and run 89/93 or 91 if its available in your area. also I'd be eagerly waiting for the 302 to seize so I could replace it with a 5.8 or a stroker winsor.
itll be near upper 2000's for rpm with 4.10s at 70. id rather have the power.
Old Aug 30, 2015 | 04:26 PM
rla2005's Avatar
rla2005
I would take the 2k RPMS at 70 MPH.
Gears are your best friend. ...assuming you can set them up. The OP already has a cam so I vote for a more reasonable gear for a towing rig....especially a 5L model.
The other consideration is whether the truck has factory converters. If so, ditch them for an aftermarket high-flow.
Old Aug 30, 2015 | 04:28 PM
'89F2urd's Avatar
'89F2urd
youd take the rpm in the upper 2000's? itd be something like 2800 give or take 100.
Old Aug 30, 2015 | 04:29 PM
rla2005's Avatar
rla2005
I read that as 2k....oops.
Edit: I see ~2400 RPM on my calculator...not bad IMHO.
Old Aug 30, 2015 | 04:36 PM
'89F2urd's Avatar
'89F2urd
which overdrive ratio did you use? 2400 isn't horrible, certainly livable, but im getting 2850 with .8 od and 4.10's
Old Aug 30, 2015 | 05:05 PM
big-ugly's Avatar
big-ugly
If it were me, I would swap to at least a 4.10 ratio (3.90 if your a cheap bastid like me and don't want to buy a new carrier) Although I'm not sure that 3.90's would make that much of a difference, or be worth the time of setting up the rear end... I also rarely drive the highway, and spend most of my time between 20-50 mph (depending on how big of hurry I am, and how bad the gravel road is that I'm traveling on), so as with everything, YMMV..
Plus, the gears would be a lot cheaper than a new set of aluminum heads..
Old Aug 30, 2015 | 05:23 PM
mtntop1's Avatar
mtntop1
I installed a 3" cat back exhaust with a magnaflow muffler.The cat is high flow.Also installed headers.The cam I installed is a Comp cam with .480 lift both intake and exhaust and and 206/216 duration.After installing all this I did notice a big improvement but I need more,that is why I was thinking of new heads to take advantage of the mods I already made.
Old Aug 30, 2015 | 05:25 PM
'89F2urd's Avatar
'89F2urd
you could do 1.7 rockers for pretty cheap, I think there are sets for a little over 200 bucks...wont be huge difference with stock heads but its in "misewell" territory.
