To enable the slide-out to extend the emergency brake pedal has to be pushed down, which causes the brake light to light up. I now have difficulty in getting the light to go on, and unless it is the slide-out will not extend. I am having to "push/release " several times b4 the light stays on.
Please help............Thanks
2001 E450 Class C
Reason: more info
Try pushing the connector on it down to make good contact. there is a possibility of a broken wire in the housing also. If the connector is tght and wires good make sure the contacts are clean and bright.
Thanks for the suggestion. I assume the connector to be the one adjacent to the emerge. brake pedal. Being 13 yrs old perhaps some rust might be a factor too.
