6.0 L Problems!
Old Aug 2, 2003 | 12:09 PM
Roger Green's Avatar
Roger Green
6.0 L Problems!
My '03 6.0L F250, with 21k miles, had a lot of power. I blew off the trubo hose, after the turbo, and now it has no power on the bottom end. The turbo doesn't hold you back like it did, it now acts like a 7.3L, on a hill. I have taken it to the dealer, and they can see the problem, but nothing comes up on the computer. I has a rough idle, blows smoke when it starts, the milage is 10 to 15 mpg. I called Ford with problem, they contacted the dealer, it is still not right and the dealer is upset because I called ford.
I just want the power I had when I bought it.
What happened? Did the turbo blow? On larger IH engines the turbo blows if the hose comes off. Why won't Ford fix it, don't they know what is wrong? Can anyone tell me?
Thanks
Roger
Old Jun 22, 2012 | 10:34 PM
LETMGRO's Avatar
LETMGRO
06' f250 6.0L in idle whines up and down ?? Just replaced turbo and it still idles up and down . I walk around to rear exaust pipe and listen to this ever 10 to 15 seconds. Any thoughts ?
Old Jun 22, 2012 | 10:40 PM
BLADE35's Avatar
BLADE35
WOOW this old thread
Just keep in mind the PCM will Sweep the Veins in turbo this will cause a sound change and does it at set intervals at Idel
any drivability Issues????
Any Gauges????
I take it this is more than the veins sweeping does run bad
Old Jun 22, 2012 | 10:49 PM
LETMGRO's Avatar
LETMGRO
these were the issues before turbo was replaced. Thought maybe to clean turbo until looked inside and saw veins were thrashed. So replaced with rebuilt and still intervals of up and down tones from idle.....thanks
Old Jun 22, 2012 | 11:20 PM
LETMGRO's Avatar
LETMGRO
Drives bad sure oh yea...replaced EGR too because of black smoke and power loss. Still smokes but very little so far. Hope to blow out any excess ****. Turbo whines up now and did not before. Hope this current issue is lighter on the wallet !
BLADE35's Avatar
BLADE35
Without a ScanGaugeII or anything of the Like your not going to get Far
Maybe run by oreilyes autoparts or autozone they scan for DTC for free
But you need to see some sensors
is the VGT Valve New too with new turbo
Old Jun 22, 2012 | 11:34 PM
LETMGRO's Avatar
LETMGRO
Replaced the turbocharger assembly ( valve not sure )
Old Jun 23, 2012 | 08:29 PM
LETMGRO's Avatar
LETMGRO
VGT Valve ? Is this the same as the Waste Gate ?
Old Jun 23, 2012 | 08:37 PM
BLADE35's Avatar
BLADE35
NO^^^^^
There is No Waiste Gate on the 6.0L they are diff than the 7.3L
The VGT Valve controls the turbo veins to control Boost output depending on the info the pcm receives from other sensors like
Acc Pedal
Baro
MAP
EBP
MAF
and may vary year to year
read threw this
http://api.viglink.com/api/click?for...13405018035693
and here
DTS Articles - Turbocharger Reconditioning
and here
https://www.ford-trucks.com/forums/8...urbo-abcs.html
Old Jun 23, 2012 | 09:22 PM
LETMGRO's Avatar
LETMGRO
Acc Pedal
Baro
MAP
EBP
MAF
Gotcha...Just replaced the EGR Valve and reading that there maybe two differ ones by production date, so I'll check that. What do you think about me checking the Temp Sensor and that it's not choked up sending EGR into a loop cycle ? Learn something every payday about my 6.0 L.
read threw this
and here
and here
https://www.ford-trucks.com/forums/8...urbo-abcs.html[/quote]
Old Jun 23, 2012 | 09:34 PM
BLADE35's Avatar
BLADE35
Well whats your ECT and EOT getting up to
The EGR Valve dont begin to work until 185* EOT IIRC
Is the truck Low on Power????
I mean the Turbo will have a change in tone as it idels this is because the PCM will sweep the Turbo Veins to keep them from sticking
so some change in turbo sound/tone is normal
Old Jun 23, 2012 | 09:53 PM
LETMGRO's Avatar
LETMGRO
OK I give up! I know enough to be dangerous about all this so if you can get me the words for ECT ? EOT IIRC ? PCM ? So I can learn to follow along with you guys. Thanks
Old Jun 23, 2012 | 09:58 PM
LETMGRO's Avatar
LETMGRO
Acc Pedal
Baro
MAP
EBP
MAF
read threw this
and here
and here
[/QUOTE]
Just saw the three links....WOW !! much to read.. thanks
Old Jun 23, 2012 | 10:24 PM
BLADE35's Avatar
BLADE35
Hey no worries I had to learn all this stuff to
EOT=Engine Oil Temp
ECT=Engine Coolant Temp
PCM=Powertrain Control Module
ACRONYMS FORD
https://www.ford-trucks.com/forums/821641-acronyms.html
Read this too^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Old Jun 23, 2012 | 10:38 PM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
ECT -engine coolant temp
EOT-engine oil temp
IIRC- if I remember correctly .lol
PCM- onboard computer
You need to go to Auto Zone and pick up a ScanguageII for $160.00 you will be able to connect to your PCM and see every sensor your truck has and these guys will help you figure out whats going wrong with it.
Blade35-Benny knows these trucks he's a Wizard..................
