Help identifying heads - pics
Old Aug 26, 2015 | 01:30 PM
Schuyles's Avatar
Schuyles
These heads are advertised as "aussie" heads on craigslist. I'm no expert, but I don't think these look like closed chambers? Is it just the gasket that makes it look like the open chambers? Any help identifying what heads these are would be great. Or any questions I can ask the seller specifically to nail down what they are. Thanks!
Old Aug 26, 2015 | 01:52 PM
dogdays's Avatar
dogdays
Closed chamber small intake ports I'd say he's telling the truth.
Look carefully at the outline of the chamber around the valves.
R.
Old Aug 26, 2015 | 04:19 PM
Schuyles's Avatar
Schuyles
Originally Posted by dogdays
Closed chamber small intake ports I'd say he's telling the truth. Look carefully at the outline of the chamber around the valves. R.
Thanks for the input! I'm going to see if I can get a better pic of the chamber and the casting number above the chamber (does that number identify it?)
Old Aug 27, 2015 | 07:50 AM
Gary Lewis's Avatar
Gary Lewis
Here's a close-up of one of the chambers. It is the gasket marks that makes it look "open".
Old Aug 27, 2015 | 08:15 AM
Schuyles's Avatar
Schuyles
Thanks again. Thanks to you guys, I am taking a second look and probably going to pick these up.
Old Aug 28, 2015 | 06:32 PM
BrutalBronco's Avatar
BrutalBronco
What size intake valve do you plan to run?
The combustion chamber really shrouds 2.19 valves. Clearancing the valve will loose points on the static compression, but that's only part of the battle.
Old Sep 1, 2015 | 09:11 AM
boss66's Avatar
boss66
I think the Aussie 302c heads had the smaller chambers while the Aussie 351c heads were bigger. Look before you leap.
Old Sep 20, 2015 | 08:19 AM
Schuyles's Avatar
Schuyles
Just following up to finish this thread. Ended up getting the heads and camshaft. I'm learning as I go and hope these will turn out to be a good addition to my 351m. Still need to get a timing set, lifters, gaskets, and other odds and ends before I try to run it.
Thanks for the help everyone.
jamies460
May 5, 2007 03:51 AM
rhpope
Apr 17, 2007 11:10 PM
Annihilator
Feb 19, 2005 04:30 PM
Matts72
Jan 1, 2005 07:58 AM
ESP351
Sep 22, 2003 05:32 AM
