1959 F-750 Fire Truck
I'm trying to get my '59 F-750 fire truck running well enough to help protect my small farm here in Idaho as we've been having a terrible fire year. I believe that the engine is a 332 c.i. I replaced the rotor, condensor, points, plugs, coil, distributor cap, and plug wires. Then I had some major fuel problems (bad fuel pump, rotten rubber lines, and a huge Holley 4 barrel that was leaking like a sieve. I've put in an electric fuel pump, new fuel lines, and a new Edelbrock 4 barrel. The truck idles great and rev's ok but under a load (driving) it bogs down and back fires. My guess is that it's either not getting enough fuel (too lean) under a load or getting too much fuel or my timing is off. I've been searching the Internet to find what the timing settings should be. I've only found some info for 332 car engines (like 3 to 5 degrees BTDC). Any suggestions?
Thanks,
Mike Lechner
Stites, Idaho
Thanks,
Mike Lechner
Stites, Idaho
Haven't dealth with that engine but if it has been sitting, does it have any obstruction in the exhaust? Have you tried posting in the FE big block section? FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) - Ford Truck Enthusiasts Forums
I have not checked for an obstruction but don't think that's the problem. Anone have any experience with vacuum governors? My old carb (Holley 4150 g) had one. My new Edelbrock doesn't have one. I'm going to plug the vaccum line that used to go to the governor and give that a try.
Thanks,
Mike
Thanks,
Mike
Glockem45
137
09-12-2022 10:19 AM
floater87
06-20-2015 10:31 AM
Bilito
06-15-2013 01:27 PM
strokerfe
17
04-08-2011 09:32 PM
gofargogo
07-27-2010 06:56 PM
