1951 F1 Panel Restore (R)
#61
New EFI gas tank from Tanks Inc.
Installed.
I've also started on the exhaust. Welding stainless with a MIG and flux core has been a learning experience.
Planning the muffler positioning.
I also got the KRC power steering pump kit installed. I removed the factory AC compressor belt tensioner and idler, and had to go to a stretch to fit AC belt.
#62
#63
#64
I have been working on finishing the exhaust system. Planning the layout.
More planning, with the rear bumper in place.
I found a receiver hitch. It needs work.
Patching the hole someone had cut in the bumper.
Rehabbed receiver hitch and bumper brackets. After blasting, straightening and paint.
Moving back to finishing the exhaust system.
The driver side view. The bumper and, receiver hitch should protect the gas tank from a rear collision.
I relocated the oil filter to the front of the frame.
Finishing up the oil filter with -10AN lines.
I put heat shields on the exhaust to protect the battery and the brake booster. Not bad for two weeks work.
#65
#69
#72
Here's a battery idea: Optima makes a 6V version of their AGM battery that can be mounted in any position even upside down. 2 of them in series can be placed behind or even under the seat, in the side compartment(s) in a panel, on their sides under the running board or bed.
If mounting a battery under the truck, why not use a drop down box rather than a hatch? How often do you need to access the battery?
#74
#75
While waiting on engine parts I have started to do some body work. One area of rust through on the wheel tub will get patches welded in.
Over all the body is in great shape. The previous owner had done the outside repairs. I don't know what these gobs of bondo are covering. Hope it's not indicative of the completed repairs.
The floor cross members are rust free. The floor was difficult to remove. The captured nuts were rusted to the bolts. I still have 3 to remove. I had to cut the bolts. When I can get the body on the hoist I'll be able to see them from the bottom.
The cab floors are rusty but sound. I'll POR 15 them then coat with bed liner top and bottom. FatMat sound deadening and carpet on top.
