I'm trying but need some help
Old Aug 18, 2015 | 11:40 PM
Dave Burner's Avatar
Dave Burner
I'm new, obviously because I use my real name, but I'm not sure that matters. Have a 1966 F250 Camper Special in incredible condition. I am a complete wanna be mechanic but so far doing OK making it mine. Did an American Autowire kit plus new gauges and a bit more than I need maybe. I pulled the old wiring and I'm on my way with the "simple instructions". Pulled the wires and started under the hood. Front end lighting looks good and works! Next gets serious for me. I have a new single wire alternator as prescribed. I get that the voltage regulator to alternator goes away. Do I toss the voltage regulator and wire everything pretty much direct as described? Feeling a bit stupid (more) but I'm actually having a lot of fun. Any help will be very much appreciated.
Old Aug 19, 2015 | 10:20 AM
svolpone's Avatar
svolpone
Hi, I did the exact same thing with my 64 2WD F100. Yes, I'm pretty sure you can remove the voltage regulator. Don't throw it away until you test everything!
You can call American Autowire for support. They are pretty eager to help. Nice guys there.
Old Aug 19, 2015 | 10:28 AM
Dave Burner
Thanks
Appreciate the response. I'll call American Autowire as well. Most of the wiring makes sense if I take my time and try to think it through. It gets a little tough with no experience to lean on.
Old Aug 19, 2015 | 10:50 AM
daveengelson's Avatar
daveengelson
I too did not know any better and used my name when I first signed up. I purchased individual harnesses for the 65; alternator, head and taillight, and although did not compare to other aftermarket harnesses I was very pleased with the quality and found American Autowire support staff very helpful. Imagine already purchased the Wiring manual, most Ford part Supplier's carry them, I went with Jim Osborn reproduction, inc for $7 plus S/H, I purchased the laminated version and found it too confusing. Suggest take on the project as a learning experience, I used the library; particularly with the body work, and painting; projects beyond my skill level, or required special tools I farmed out. Looking forward to your input on how your projects coming.
Old Aug 19, 2015 | 11:03 AM
Dave Burner
Thanks, helps me to know that I'm not the only one learning. I did get the wiring manual and have needed it. The internet has saved my life/project as well. I'll figure out how to put some photos on the site. You'll hear more requests for help from me, I'm sure.
rio68
Aug 2, 2019 11:12 AM
seadonkey79
26
May 5, 2019 11:50 PM
F100Jay
Apr 6, 2015 02:51 AM
mOROTBREATH
57
Mar 3, 2011 06:33 PM
nathanamorgan
Dec 29, 2008 02:02 PM
