1978 - 1996 Big Bronco
Water Leak
Old Aug 1, 2003 | 09:24 PM
Bob 86's Avatar
Bob 86
Water Leak
I have a 96 bronco, and I keep getting water in the b-pillar section of the truck. Right behind where the seat belt bolts to the body. When I shine a light up the pilar to see where the leak is, I can't up through the bracing. I noticed that on the outside where the roof and quarter panel joint is there is a hairline crack. Is it possible for warter to get in through there or more likely is it the top leaking? I know the top is leaking on the passenger side cause I'm getting water comming out of the rear speaker area. I'm trying to stop this cause the darn truck is starting to rust from the inside out. Any ideas, and what can I use to seal the cracks. Thanks Bob
Old Aug 1, 2003 | 10:39 PM
cajunbronco's Avatar
cajunbronco
Water Leak
Cracks at the rain gutter are pretty common.You can seal it up with silicone.The real fix is to weld it up and paint it.silicone is cheap.
CB
Old Aug 2, 2003 | 12:09 AM
mrit's Avatar
mrit
Water Leak
yea, cajunbronco is right. I had BAD leaks in those rain gutters with my Bronco II and it ruined the whole headliner. Used a tube of clear silicone and it stopped all the leaks and you cant even see it.
Old Aug 2, 2003 | 06:47 AM
Bob 86's Avatar
Bob 86
Water Leak
Did you pull the headliner and seal it from the inside? I just had the headliner out to install a overhead console and I never dawned on me to look at the seems. Guess i know what I will be doing later this weekend.
Old Aug 2, 2003 | 02:38 PM
bigric's Avatar
bigric
Water Leak
Read this thread. It also links to several other threads.
Old Aug 3, 2003 | 09:50 AM
bigric's Avatar
bigric
Water Leak
Um, sorry about that. Instead, try this more fulfulling link:
https://www.ford-trucks.com/forums/s...t=%25252Bcrack
rnelson664
Apr 29, 2021 09:56 AM
bsa_bob
Sep 29, 2011 09:10 AM
knoxvegasdaddy
Sep 15, 2011 03:36 AM
bob1963f100
Feb 10, 2004 07:19 PM
Torky2
Dec 1, 2003 08:29 AM
